Re: need some intake help
its a intake air temp sensor, it tells the car the temp of the air entering the engine, so inside the cone works. or zip tie it to the cone, rip open the mesh a bit for the zit tie to fit, and done, zip ties seem safer for the wires to me, hide it on the back side i guess.
asite57
what is the IATand how important is it if i just left it dangling
It's the Intake Air Temp sensor...
It reads the ambient air temps...
You drive a 3800...regardless of intake placement the air coming in is going to get hot...
I used the Silicone coupler from Spectre with a small 45* polished elbow (looks).
http://i1165.photobucket.com/albums/...P/IMAG1521.jpg
http://i1165.photobucket.com/albums/...P/IMAG1520.jpg
Drilled a 7/8 hole into the rubber for the IAT and cleaned it with an exacto knife. Fit well and tight. With the filter (9" Spectre) it wasn't too expensive, close to $60.
Iceman6669 thats exactly what i want to do to make it look just like that! but dont forget my original goal was to make the supercharger whine more
asite57
Trust me you will hear it whine more... Really good at WOT.
Iceman6669
It does, even at idle you can hear it more... that makes you want to port it and make it even whinier!
hahahaha, is that a word???
(whinier)
It is hitting the stuff behind it a little bit, but its not too bad. It sounds A LOT better, very very happy.
http://img96.imageshack.us/img96/288...0131124201.jpg
GTLGDP thats what i was looking at doing putting an spectra filter about that size on the end like that but did you have to tuck any sensors or anything like that? did it through any codes?
Yeah i tucked the temperature sensor inside of it, then tightened the ring. I wouldn't know if its throwing a code or not because i already have my SES light on due to an o2 sensor code.
Will this set-up work on an 04+? I like Coolone's setup. It looks neat. Do i have the same sensors?
