I replaced the front passenger door on my 99 GTP with a door off a 03 SE. Everything worked on the passenger door on the GTP, it just had some cosmetic exterior body damage that I wanted to swap doors with. Noticable differences were that the passenger door off the 03 doesn't have a key cylinder and the wiring harness plugs were different. I took the complete wiring harness out of the SE door and took the window motor off the GTP door as well as the complete wiring harness out of the GTP door. Got it all hooked up and the power window would not work, neither from the passenger switch or the driver switch, however the door lock did work from both passenger and driver. I inspected the window switch and it seemed fine. I took the window motor off (that was working fine a week ago when I took the GTP door off) and inspected it, even taking it apart to clean the points. Hooking it directly to the battery the motor worked fine in both directions. Putting a test light to all the wires on the switch and to the window motor I got nothing. Unplugging the door harness I touched each of the male posts, a couple on the bottom locked and unlocked the door when I touched them but other wise no lights. I had someone else press the passenger window switch on the driver controls while I stuck a light to each. Pulling on the harness a bit I was able to get two different posts to light up at different times, as in when up was pressed on the passenger switch from the driver control one post would light, same if pressing down on another post. I plugged the harness back together and ran a test light on the wires going to the passenger motor and sure enough they had power, but the window didn't move. I could feel the motor click when pressed but it didn't roll the window. Checking the harness again I had no power when the button was pressed but if I pulled on the harness again it would light up. I know I have a short in that harness somewhere, I pulled the carpet back a little to see but everything is pretty well taped up and secured, what could be causing this?
