Thread: Scraping noise at low speeds.
Results 1 to 20 of 29
  1. #1 Re: Scraping noise at low speeds.
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by Zef_66 View Post
    Could be that you have something rubbing on your rotor. Like the little bracket that holds the ABS sensor connector. I've done that before.
    You mean the little black metal piece under the rotor (at 6 O'clock)? I checked to make sure it wasn't bent up and touching the rotor. So it's not that.
    Or it is a possibility that the calipers are not retracting all the way and you have a pad or one of the metal clips rubbing lightly on the rotor.
    I thought it might be the caliper. It's weird because when I have the car up on jacks with the wheels off, and in drive, the driver's side wheel hardly spins, yet the passenger one spins freely. However, the sound I'm hearing is coming from the passenger side. I pulled the drivers caliper off anyway, and pulled out the piston and lubricated it with some brake fluid, as well as greased the slide pins. I also bled the brakes. I put it back together, and it span freely for a bit, but then I had the same issue. I don't know if this is related to the problem or not (different wheel alltogether).
    Try to jack up that side and spin the tire by hand to isolate where the noise is coming from.
    I can't hear the noise up on jacks. I only hear it when I'm driving.
  2. #2 Re: Scraping noise at low speeds.
    PA
    Quote Originally Posted by Bedwards View Post
    I would check the play in your wheel bearings then. I had an issue where I had a wheel bearing go bad. It didn't groan or throw any ABS lights. But I heard a scraping noise from the drivers side. Pulled the wheel to find the wheel was grinding on the strut because the wheel bearing was bad and allowing the wheel to tilt in.
    So check your bearings.
    2001 GSE
  3. #3 Re: Scraping noise at low speeds.
    Checked for wheel play. Nothing out of the ordinary. Hmm...
  4. #4 Re: Scraping noise at low speeds.
    GT Level Member RegalGS98s's Avatar
    NJ
    Sounds like the wheel bearing again. Did you change it yet from the last post? Did you try loading the bearing test I recommended? I doubt this, but check the inside of your rim and the strut for rub marks. When did this noise start to appear?
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  5. #5 Re: Scraping noise at low speeds.
    Quote Originally Posted by RegalGS98s View Post
    I haven't changed the bearing. What load test? Turning and listening for a change in sound? I hear the sound more in straight line. It doesn't seem like turning affects the noise. This noise started after putting the new cam in. I changed the axle at the same time too. Ever since then.
  6. #6 Re: Scraping noise at low speeds.
    NJ
    When I had my bearing go bad, you couldn't feel it by grabbing the tire. I had to do a load test. As you drive at maybe 20-30 mph, try steering the car left to right. Think they call it loading the bearing. If your steering to the left and the noise gets louder, it's your right bearing. If you steer to the right and it's louder, it's your left. You say your wheel bearings keep going bad. Are they a good brand and are you torquing the axle nut to spec? When I first had the car and had someone else change the wheel bearing, they torqued it down with an impact and it looked like they were making it kind of tight. 6 months later, the bearing failed. I changed it myself next time and torqued to spec. Torque varies by year. About 70k miles later, the bearing is still good, just have problems with the wheel speed sensor wires.
    Basically you would rock the car back and forth and from the weight of the car transferring onto that side, it would put more of a load on that bearing so it would make more noise. Re-torquing the axle nut at this point wouldn't make the noise go away. Damage would be done if that was the problem. This might seem like a lot of work, but could try swapping the left and right side bearings and see if the noise appears on the left side instead of the right.
  7. #7 Re: Scraping noise at low speeds.
    The noise is also only when my foot is on the gas. If I cruise with my foot off the gas, it goes away. Wouldn't the wheel bearing continue to make noise?
  1. Car dies at idle or low speeds
    By mikejon in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-17-2013, 10:44 AM
  2. Vibration at highway speeds
    By carl06GT in forum Brakes/Suspension/Chassis
    Last Post: 09-27-2010, 08:10 PM
  3. 95 GP Shudder at High Speeds
    By TheDude in forum General Tech Discussion
    Last Post: 04-15-2010, 10:00 AM
  4. metallic scraping
    By hacket in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-28-2009, 10:52 PM
  5. Ive been scraping my exhaust -.-
    By rocafella2032 in forum General Tech Discussion
    Last Post: 10-10-2009, 01:36 PM
