Thread: Scraping noise at low speeds.
Results 1 to 20 of 29
Bedwards Scraping noise at low speeds. 07-07-2011, 08:53 AM
Zef_66 Re: Scraping noise at low... 07-07-2011, 10:25 AM
Bedwards Re: Scraping noise at low... 07-07-2011, 10:46 AM
Zef_66 Re: Scraping noise at low... 07-07-2011, 10:56 AM
Bedwards Re: Scraping noise at low... 07-11-2011, 08:46 AM
RegalGS98s Re: Scraping noise at low... 07-11-2011, 09:12 AM
Bedwards Re: Scraping noise at low... 07-11-2011, 09:52 AM
RegalGS98s Re: Scraping noise at low... 07-11-2011, 10:23 AM
Bedwards Re: Scraping noise at low... 07-11-2011, 12:36 PM
RegalGS98s Re: Scraping noise at low... 07-12-2011, 06:50 AM
Bedwards Re: Scraping noise at low... 07-12-2011, 08:32 AM
RegalGS98s Re: Scraping noise at low... 07-12-2011, 09:03 AM
Bedwards Re: Scraping noise at low... 07-12-2011, 05:16 PM
RegalGS98s Re: Scraping noise at low... 07-13-2011, 06:47 AM
Bedwards Re: Scraping noise at low... 07-13-2011, 10:37 AM
RegalGS98s Re: Scraping noise at low... 07-13-2011, 11:08 AM
Scottydoggs Re: Scraping noise at low... 07-13-2011, 11:08 AM
Bedwards Re: Scraping noise at low... 07-23-2011, 02:23 PM
RegalGS98s Re: Scraping noise at low... 07-26-2011, 07:47 AM
Bedwards Re: Scraping noise at low... 08-16-2011, 05:21 PM
av415 Re: Scraping noise at low... 09-04-2011, 03:48 PM
  1. #1 Re: Scraping noise at low speeds.
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by RegalGS98s View Post
    Have you tried doing the load test driving with your foot off the gas? If it doesn't make a difference in the noise then to me it would have to point to a transmission problem. I know you changed the axle also, but that should make noise if you're on the gas or not. I assume when you say on the gas, you mean just enough gas to accelerate easily or maintain speed, not a hard acceleration.
    I'll try the load tests tonight. I mostly hear the noise at about 1600-1800 RPM.
  2. #2 Re: Scraping noise at low speeds.
    GT Level Member RegalGS98s's Avatar
    NJ
    Also to see if it's the brakes, try riding the brakes with the gas. Just apply the brakes enough for them to touch.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  3. #3 Re: Scraping noise at low speeds.
    I tried turning and load testing the bearings. The noise stayed the same no matter what. I also tried applying the brakes, it didn't stop the noise. The noise also happens in reverse, around the same RPM.
  4. #4 Re: Scraping noise at low speeds.
    NJ
    Now I'm thinking it's a problem with your engine again since it's only at certain RPM's. Timing chain or the timing chain dampener if you used one. I don't remember all the things you changed.
  5. #5 Re: Scraping noise at low speeds.
    I did replace the timing chain and timing chain dampner. Why would that be making noise? I installed it correctly... And wouldn't it make the noise if I revved the engine in drive (up on jacks), or in neutral? If it is the chain, will the noise eventually go away as it wears, or what should I do?
  6. #6 Re: Scraping noise at low speeds.
    NJ
    Is it the same chain that was used while the pushrods were being bent, it might of stretched? But yeah, I would think it would make noise when reving the engine on jacks.
  7. #7 Re: Scraping noise at low speeds.
    so you only hear this noise when the car is moving and on the ground?, and you hear nothing when its in the air in drive, and hear nothing when its in park, even if yo u rev it up a bit.
    that would be a odd one for sure. maybe trans related, bad gears or something.
    i dont know jack about fwd transmissions but when a rwd ring and pinion set goes bad, they tend to make noise when off the gas rolling,(down shifting) like a ringing/hum. and if you would goose the gas( like give it just enough gas to start moving the car while moving and then let off) while in low gear you could feel the slop in the gears.
  8. #8 Re: Scraping noise at low speeds.
    NJ
    I haven't done this, but if the axle is not inserted all the way, wonder if it would make this noise when under load. It only making the noise at certain RPM is what is perplexing me. I would point to the Engine or the input side of the transmission for RPMs.
  1. Car dies at idle or low speeds
    By mikejon in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-17-2013, 10:44 AM
  2. Vibration at highway speeds
    By carl06GT in forum Brakes/Suspension/Chassis
    Last Post: 09-27-2010, 08:10 PM
  3. 95 GP Shudder at High Speeds
    By TheDude in forum General Tech Discussion
    Last Post: 04-15-2010, 10:00 AM
  4. metallic scraping
    By hacket in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-28-2009, 10:52 PM
  5. Ive been scraping my exhaust -.-
    By rocafella2032 in forum General Tech Discussion
    Last Post: 10-10-2009, 01:36 PM
