Thread: Scraping noise at low speeds.
Results 1 to 20 of 29
  1. #1 Re: Scraping noise at low speeds.
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I did replace the timing chain and timing chain dampner. Why would that be making noise? I installed it correctly... And wouldn't it make the noise if I revved the engine in drive (up on jacks), or in neutral? If it is the chain, will the noise eventually go away as it wears, or what should I do?
  2. #2 Re: Scraping noise at low speeds.
    GT Level Member RegalGS98s's Avatar
    NJ
    Is it the same chain that was used while the pushrods were being bent, it might of stretched? But yeah, I would think it would make noise when reving the engine on jacks.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  3. #3 Re: Scraping noise at low speeds.
    so you only hear this noise when the car is moving and on the ground?, and you hear nothing when its in the air in drive, and hear nothing when its in park, even if yo u rev it up a bit.
    that would be a odd one for sure. maybe trans related, bad gears or something.
    i dont know jack about fwd transmissions but when a rwd ring and pinion set goes bad, they tend to make noise when off the gas rolling,(down shifting) like a ringing/hum. and if you would goose the gas( like give it just enough gas to start moving the car while moving and then let off) while in low gear you could feel the slop in the gears.
  4. #4 Re: Scraping noise at low speeds.
    NJ
    I haven't done this, but if the axle is not inserted all the way, wonder if it would make this noise when under load. It only making the noise at certain RPM is what is perplexing me. I would point to the Engine or the input side of the transmission for RPMs.
  5. #5 Re: Scraping noise at low speeds.
    PA
    Wait, what? You bent pushrods and then replaced the timing chain? Did you break the chain? What exactly happened and how long ago? Could shed some light.
    2001 GSE
  6. #6 Re: Scraping noise at low speeds.
    I have the huge long thread about the car not starting after the cam install. It ended up being the valve keepers on upside down. Mangled a bunch of pushrods. Would that stretch the chain though?
  7. #7 Re: Scraping noise at low speeds.
    NJ
    Please list everything that has been changed and broke since that other thread started. 22 pages is a lot to fish through. This would help everyone.
  8. #8 Re: Scraping noise at low speeds.
    New parts:
    VS cam
    G8 springs and retainers
    Stock pushrods
    Stock timing chain and dampener
    LS7 lifters
    Stock valve seals
    All new gaskets (head, LIM, front cover, water pump, supercharger etc.)
    Passenger CV joint/axle
    Passenger side ball joint
    LS7 lifters, new pushrods, new gaskets, new valve seals, axle and the ball joint were all put in after the valve keeper incident.
  1. Car dies at idle or low speeds
    By mikejon in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-17-2013, 10:44 AM
  2. Vibration at highway speeds
    By carl06GT in forum Brakes/Suspension/Chassis
    Last Post: 09-27-2010, 08:10 PM
  3. 95 GP Shudder at High Speeds
    By TheDude in forum General Tech Discussion
    Last Post: 04-15-2010, 10:00 AM
  4. metallic scraping
    By hacket in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-28-2009, 10:52 PM
  5. Ive been scraping my exhaust -.-
    By rocafella2032 in forum General Tech Discussion
    Last Post: 10-10-2009, 01:36 PM
