Thread: Scraping noise at low speeds.
Results 1 to 20 of 29
Bedwards Scraping noise at low speeds. 07-07-2011, 08:53 AM
Zef_66 Re: Scraping noise at low... 07-07-2011, 10:25 AM
Bedwards Re: Scraping noise at low... 07-07-2011, 10:46 AM
Zef_66 Re: Scraping noise at low... 07-07-2011, 10:56 AM
Bedwards Re: Scraping noise at low... 07-11-2011, 08:46 AM
Bedwards Re: Scraping noise at low... 07-23-2011, 02:23 PM
RegalGS98s Re: Scraping noise at low... 07-26-2011, 07:47 AM
Bedwards Re: Scraping noise at low... 08-16-2011, 05:21 PM
av415 Re: Scraping noise at low... 09-04-2011, 03:48 PM
  1. #1 Scraping noise at low speeds.
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Hey guys. I'm getting a light, metallic scraping noise coming from the passenger wheel (I think) at speeds up to about 50 km/hr. It doesn't seem to change frequency with an increase in speed, or a turn. It also is only heard when my foot is on the gas. As soon as I take my foot off, it disappears. I haven't checked for wheel play yet, but to me, this doesn't feel or sound like a wheel bearing. I'm having trouble figuring this one out.
    My brake pads and rotors are no more than 6 months old. I just replaced the passenger side CV joint as well
  2. #2 Re: Scraping noise at low speeds.
    PA
    Could be that you have something rubbing on your rotor. Like the little bracket that holds the ABS sensor connector. I've done that before.
    Or it is a possibility that the calipers are not retracting all the way and you have a pad or one of the metal clips rubbing lightly on the rotor.
    Try to jack up that side and spin the tire by hand to isolate where the noise is coming from.
    2001 GSE
  3. #3 Re: Scraping noise at low speeds.
    Quote Originally Posted by Zef_66 View Post
    You mean the little black metal piece under the rotor (at 6 O'clock)? I checked to make sure it wasn't bent up and touching the rotor. So it's not that.
    I thought it might be the caliper. It's weird because when I have the car up on jacks with the wheels off, and in drive, the driver's side wheel hardly spins, yet the passenger one spins freely. However, the sound I'm hearing is coming from the passenger side. I pulled the drivers caliper off anyway, and pulled out the piston and lubricated it with some brake fluid, as well as greased the slide pins. I also bled the brakes. I put it back together, and it span freely for a bit, but then I had the same issue. I don't know if this is related to the problem or not (different wheel alltogether).
    I can't hear the noise up on jacks. I only hear it when I'm driving.
  4. #4 Re: Scraping noise at low speeds.
    PA
    Quote Originally Posted by Bedwards View Post
    I would check the play in your wheel bearings then. I had an issue where I had a wheel bearing go bad. It didn't groan or throw any ABS lights. But I heard a scraping noise from the drivers side. Pulled the wheel to find the wheel was grinding on the strut because the wheel bearing was bad and allowing the wheel to tilt in.
    So check your bearings.
    2001 GSE
  5. #5 Re: Scraping noise at low speeds.
    Checked for wheel play. Nothing out of the ordinary. Hmm...
  6. #6 Re: Scraping noise at low speeds.
    GT Level Member RegalGS98s's Avatar
    NJ
    Sounds like the wheel bearing again. Did you change it yet from the last post? Did you try loading the bearing test I recommended? I doubt this, but check the inside of your rim and the strut for rub marks. When did this noise start to appear?
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  7. #7 Re: Scraping noise at low speeds.
    I put the car in park and throttled it up to the 1400-1800 RPM range and I can hear the noise. So it's gotta be engine related. I'm just confused on what would cause this noise.
  8. #8 Re: Scraping noise at low speeds.
    NJ
    I know timing belts stretch... But I've never heard of a chain stretching. I know they wear, but this chain is brand new. Couldn't have worn that fast. The only thing I can think of is if the tensioner was somehow lose, and the chain was rubbing on the block or something. But even still, I get no noise when the car is up on jacks, in drive.
    You should see how much the chain that was on my Regal stretched. The tensioner was hardly doing anything anymore. Yeah it had 200k miles on it, but they do stretch.
    So now it does it in park vs before only when driving? Please check the timing chain before something serious fails. At least have someone rev the car while you're checking for where the noise is coming from. The gaskets for the front aren't that much if it is the timing chain.
  9. #9 Re: Scraping noise at low speeds.
    It might have always done it in park, I could just never really hear it I guess. I must have forgot to roll down the passenger window. I'll check the chain this weekend. Could the oil pump cause this?
  10. #10 Re: Scraping noise at low speeds.
    SE Level Member av415's Avatar
    Sep 2011
    San Francisco
    I have that same problem on my front drivers side wheel. i have noticed a slight scratch on my shock which i replaced recently as well as the bearing.
  1. Car dies at idle or low speeds
    By mikejon in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-17-2013, 10:44 AM
  2. Vibration at highway speeds
    By carl06GT in forum Brakes/Suspension/Chassis
    Last Post: 09-27-2010, 08:10 PM
  3. 95 GP Shudder at High Speeds
    By TheDude in forum General Tech Discussion
    Last Post: 04-15-2010, 10:00 AM
  4. metallic scraping
    By hacket in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-28-2009, 10:52 PM
  5. Ive been scraping my exhaust -.-
    By rocafella2032 in forum General Tech Discussion
    Last Post: 10-10-2009, 01:36 PM
