Please post which ones you are unsure of and we'll fill in the info.
Bolt locations. You mean like the trans to engine bolts, the backwards bolt? Let's walk right in to see it. These pics are w/o bolt in, so you see a silver dot.
Without the car in the way.
Backwards (1 bolt 18mm)
Regulars (4 bolts 18mm) Note, the 2 o'clock position is a dowel pin only, no bolt.
Diff to engine bracket (4 bolts 13mm)
