Thread: engine swap 3800 sc to same but not burned engine
Results 1 to 9 of 9
roger7 engine swap 3800 sc to same... 03-07-2011, 09:28 PM
TheOtherNick Re: engine swap 3800 sc to... 03-07-2011, 09:30 PM
benner Re: engine swap 3800 sc to... 03-07-2011, 09:32 PM
Mike Kopstain Re: engine swap 3800 sc to... 03-07-2011, 09:35 PM
BillBoost37 Re: engine swap 3800 sc to... 03-08-2011, 07:34 AM
Reptile Re: engine swap 3800 sc to... 03-08-2011, 02:57 PM
roger7 Re: engine swap 3800 sc to... 03-08-2011, 09:56 PM
BillBoost37 Re: engine swap 3800 sc to... 03-09-2011, 07:00 AM
roger7 Re: engine swap 3800 sc to... 03-10-2011, 01:59 PM
  1. #1 engine swap 3800 sc to same but not burned engine
    SE Level Member roger7's Avatar
    Son, Mex
    hey everybody i need help with my gtp 98, my car got burned and i changed the engine the sc and wiring harness
    the problem is that when i turn on the car it turns off but it lasts about 4 secs and i can do this as many times as i turn on the car
    is this wiring problem? or mechanic?
    apparently there is something that protects the engine when it's out of gas is that possible?
  2. #2 Re: engine swap 3800 sc to same but not burned engine
    Charles City, IA
    Is the security light flashing?
    SMGPFC Two Nipple General
  3. #3 Re: engine swap 3800 sc to same but not burned engine
    Delaware, OH
    That was gonna be my question. Sounds like a security issue
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  4. #4 Re: engine swap 3800 sc to same but not burned engine
    SE Level Member Mike Kopstain's Avatar
    Chicago, IL
    Check the fuel pump resistor... Bypass it like so and see if the car stays on.
    Thinking about shopping with ZZP or the other guys? - Order with us instead and we'll give you a 5% off coupon code for your next order! Click here to learn how!
    Like us on Facebook!
  5. #5 Re: engine swap 3800 sc to same but not burned engine
    I see three things possible.
    1. Security light should be flashing and not solid. Solid means security is piss off (I'm right guys, solid is bad ...uh right?)
    2. Maf sensor is bad. Unhook it and you'll probably need a little throttle to get it going and keep it going, but it'll run off a table after a couple of minutes.
    3. Fuel pump resistor. Although i thought this was mostly common once the resisitor had a chance to warm up.
  6. #6 Re: engine swap 3800 sc to same but not burned engine
    Bastard Reptile's Avatar
    Kansas City, MO
    I'm sorry, this just struck me as hilarious. Almost with a British accent.
    I think that if it flashes it's pissed. A start/run for 2 seconds sounds just like the security feature. You might have to try the 30 learn procedure?
  7. #7 Re: engine swap 3800 sc to same but not burned engine
    Son, Mex
    the bypass on the relay worked!! thanks a lot Mike Kopstain, so i just have to buy a new relay?
  8. #8 Re: engine swap 3800 sc to same but not burned engine
    No, that means the fuel pump resistor is bad. You can leave the relay that way and be fine. Or you can get a new fuel pump resistor and replace it.
  9. #9 Re: engine swap 3800 sc to same but not burned engine
    Son, Mex
    thanks a lot
  1. 3800 Engine swap question (lesabre to GP)
    By 1gr869 in forum General Tech Discussion
    Last Post: 01-19-2011, 10:50 PM
  2. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  3. 3800 sc engine
    By Brandon Busenitz in forum Engine
    Last Post: 04-13-2010, 02:37 PM
  4. 3800 engine swap
    By M.$tErNeR in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-26-2009, 05:26 PM
  5. i need help! engine ticking?? 3800
    By a.caldwell11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2009, 03:45 PM
