Thread: best year for GTP, 98-2002.
Page 3 of 3 FirstFirst 123
Results 41 to 57 of 57
  1. #41 Re: best year for GTP, 98-2002.
    Banned
    Apr 2011
    wv
    kid? im probably older than you. and the injector harness clips are clearly not the same. the coolant bottle on the 98 is under the support beam where as 2000 and up, theyre right in front of the belt tensioner which makes changing belts overly complicated
  2. #42 Re: best year for GTP, 98-2002.
    Quote Originally Posted by L36pro View Post
    Your not, 20 year old.
    Then your clearly blind...because they are.
    97-98's had the coolant bottle had the right.
    Anything newer than that...they are on the strut tower.
    It comes off with 2 10mm nuts.
    It's easy.
  3. #43 Re: best year for GTP, 98-2002.
    SE Level Member joelnv02GTP's Avatar
    alberta, canada
    i have an 02 and changing my belts is never complicated
  4. #44 Re: best year for GTP, 98-2002.
    Banned
    Apr 2011
    wv
    well maybe the gtp's are different but ive got a 98, 2000, and 01 gt. 98 is under the support to the right. 2000, and 01 are between the panel and the belt. getting a wrench on there to get the belt off sucks
  5. #45 Re: best year for GTP, 98-2002.
    Because your supposed to remove it guy.
    *sigh*
  6. #46 Re: best year for GTP, 98-2002.
    Banned
    Apr 2011
    wv
    well i like not removing it. the layout is way better on the 98
  7. #47 Re: best year for GTP, 98-2002.
    try saying that after you try and put a decent intake on the car.
  8. #48 Re: best year for GTP, 98-2002.
    Banned
    Apr 2011
    wv
    and the coupes are better looking. sorry to hurt your feelings friend
  9. #49 Re: best year for GTP, 98-2002.
    Isn't the intake performance setups different on the 83's and the 2010's for the 5.7 OHV VVT straight 8?
    That might be your opinion youngin...but nothing in this thread makes sense that you say.
  10. #50 Re: best year for GTP, 98-2002.
    alberta, canada
    it literally takes a minute to remove it, thats if you know how
  11. #51 Re: best year for GTP, 98-2002.
    Banned
    Apr 2011
    wv
    the stock intake is fine. its fenderwell. the only issue is the pcm placement and the tubing, which is slightly turbulent due to the ability of the engine to move in the compartment
  12. #52 Re: best year for GTP, 98-2002.
    North Jersey
    yea im pretty sure my '99 GTP car has a carburetor
  13. #53 Re: best year for GTP, 98-2002.
    Banned
    Apr 2011
    wv
    yeah and the fuse bix takes litterally a minute to remove, but if i had to remove it evertime i wanted to change a fuse i would get pretty impatient
  14. #54 Re: best year for GTP, 98-2002.
    the stock intake is not fenderwell, nor good for performance.
  15. #55 Re: best year for GTP, 98-2002.
    Banned
    Apr 2011
    wv
    uhh it is indeed fenderwell. take the airbox out and see where it goes
  16. #56 Re: best year for GTP, 98-2002.
    Truth.
    Christ almighty...it goes to the BACK OF YOUR HEADLIGHT...NOT YOUR FENDER. LOOK AGAIN.
    This thread is going nowhere.
  17. #57 Re: best year for GTP, 98-2002.
    try again.
    please breathe through a straw for a while and tell me how it works out.
  1. One year later
    By JCG's-GTP in forum Off Topic Discussion
    Last Post: 08-07-2010, 02:49 PM
  2. what year is this considered
    By almighty in forum General Tech Discussion
    Last Post: 12-29-2009, 08:42 PM
  3. What year model GTP........
    By rodie1200 in forum Off Topic Discussion
    Last Post: 07-30-2009, 01:51 PM
  4. How to tell the year of a gp
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 05-09-2009, 10:06 AM
  5. Happy new year
    By 1998xGTP in forum Off Topic Discussion
    Last Post: 01-04-2009, 12:11 PM
