Quote Originally Posted by L36pro View Post
kid? im probably older than you
Your not, 20 year old.
the injector harness clips are clearly not the same.
Then your clearly blind...because they are.
the coolant bottle on the 98 is under the support beam where as 2000 and up, theyre right in front of the belt tensioner which makes changing belts overly complicated
97-98's had the coolant bottle had the right.
Anything newer than that...they are on the strut tower.
It comes off with 2 10mm nuts.
It's easy.
