Thread: Which oil do you use?
Results 1 to 20 of 22
Couch Which oil do you use? 04-15-2011, 08:41 AM
Bio248 Re: Which oil do you use? 04-15-2011, 08:46 AM
cerick08GP Re: Which oil do you use? 04-15-2011, 11:27 AM
starscream5000 Re: Which oil do you use? 04-15-2011, 11:47 AM
TheOtherNick Re: Which oil do you use? 04-15-2011, 12:35 PM
blueguy Re: Which oil do you use? 04-15-2011, 12:35 PM
FordMan77 Re: Which oil do you use? 04-26-2011, 04:32 PM
blueguy Re: Which oil do you use? 04-27-2011, 10:08 AM
BlackSun Re: Which oil do you use? 04-16-2011, 10:46 AM
2000SILVERSE3800 Re: Which oil do you use? 04-26-2011, 01:37 PM
matt5112 Re: Which oil do you use? 04-26-2011, 01:41 PM
EJOUIE Re: Which oil do you use? 04-26-2011, 04:35 PM
vincegpking Re: Which oil do you use? 04-26-2011, 05:23 PM
Wotgtp Re: Which oil do you use? 04-26-2011, 05:37 PM
matt5112 Re: Which oil do you use? 04-26-2011, 06:16 PM
Wotgtp Re: Which oil do you use? 04-26-2011, 06:45 PM
matt5112 Re: Which oil do you use? 04-26-2011, 06:47 PM
jcmonteman Re: Which oil do you use? 04-26-2011, 06:47 PM
Wotgtp Re: Which oil do you use? 04-26-2011, 06:52 PM
matt5112 Re: Which oil do you use? 04-26-2011, 07:30 PM
Couch Re: Which oil do you use? 04-27-2011, 09:08 AM
Toofastgs Re: Which oil do you use? 04-27-2011, 01:21 AM
  1. #1 Which oil do you use?
    Chilliwack BC
    Didn't see a thread like this thought i'd ask the age old question which oil do you use/prefer?
    I have been using mobil 1 0w20 full synthetic for the past year. Biggest difference i've noticed is on cold starts. Haven't had to use my block heater all winter.
    www.bobtheoilguy.com
    this website contains all if not too much info on oil for anything.
  2. #2 Re: Which oil do you use?
  3. #3 Re: Which oil do you use?
    GTX Level Member cerick08GP's Avatar
    Ya, I go on BITOG and look around often. It has some good info, and some not so good.
    The 3800 engine is very tolerant to different oil brands and viscosities, like you mentioned it has been discussed many times. And pretty much any oil changed regularly is just fine. My current oil choice is the least expensive conventional 5W-30 oil with moly changed out every 5k.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: Which oil do you use?
    GT Level Member starscream5000's Avatar
    Kentucky
    I use German Castrol 0W30, otherwise known as Castrol Syntec 0W30 European Formula. It's the only true full synthetic Castrol offers (last I checked was over a year ago, so this could be different).
    I change it every 7000 miles with an oil filter changed out and re-primed half way through.
    Cold starts gives me about 80-84 psi, hot idle (over 180 degrees) gives me about 52-60 psi depending on how hot the oil actually is. Hot cruizing on the freeway I have a steady 70-75 psi at about 60 MPH.
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  5. #5 Re: Which oil do you use?
    Charles City, IA
    Amsoil 10w-40 racing oil.
    SMGPFC Two Nipple General
  6. #6 Re: Which oil do you use?
    Valvoline VR-1 20W-50 Racing Oil
  7. #7 Re: Which oil do you use?
    St. Louis
    I see someone likes the extra ZDDP for their engine. I run the same oil in my 74 MG. Good stuff.
  8. #8 Re: Which oil do you use?
    Quote Originally Posted by FordMan77 View Post
    My uncle runs it in his BBC...
    And plenty of dirt track races use it as well...even though they rebuild motors nearly every season...it helps to keep bearings/wear in check for sure...as well as oil pressure.
  9. #9 Re: Which oil do you use?
    Nov 2010
    Marine City MI
    Schaeffers synthetic supreme 7000 10w-30.
    99 GTP, ZZP MPS 2.9 pulley, GenIII supercharger ported & polished, machined intake W/ stage 2 intercooler, XP Cam,ZZP fuel rails, 42.5 injectors, Wizard CAI, custom headers, 3 inch downpipe, into dynomax muffler,180 stat, Northstar TB, 85mm MAF, ZZP trans, 3.29 gears, input shaft and torque converter, stock heads W/Ls6 springs.
  10. #10 Re: Which oil do you use?
    Donating Users
    GRAND RAPIDS, MI
    Mobil 1 10w-30 with wix filter changed every 3000 miles
    2000 Grand Prix SE: Knocking rod mod and broken timing chain mod. L67 coming soon!
  11. #11 Re: Which oil do you use?
    Someone be a champ and run mobil 1 5W-20 or 0W-20.
    After I'm all out of mobil 1 5W-30 I'm going to try 0W-20 or 0W-40.
  12. #12 Re: Which oil do you use?
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    water from the garden hose
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  13. #13 Re: Which oil do you use?
    hanover park, IL
    Mobil 1 10w30 with the bigger oil filter every 3k
    2000 gtp- u-bend and res delete, hot air intake, flipped mounts, 104s, larger front sway bar, fbody front brakes, custom embroided floormats, custom carpeting,
  14. #14 Re: Which oil do you use?
    Mullet Member Wotgtp's Avatar
    Connecticut
    Royal purple 10w-30. Im going to try 5w-30 next oil change to see if I get any positive benifits.
  15. #15 Re: Which oil do you use?
    it'll be thinner when its cold, less wear.
    Will you notice it?
    I hope not.
  16. #16 Re: Which oil do you use?
    Connecticut
    Im aware that its thinner at startup/cold, but in my blazer I had noticed had worse mileage with 10w-30 then 5w-30. So my broscience says I could get better mileage with a thinner oil while not going too thin. Worst comes to worst I gain nothing and its the same with no extra cost to me.
  17. #17 Re: Which oil do you use?
    go for 0W-30 then?
  18. #18 Re: Which oil do you use?
    Banned Trolling GPF
    go for 0W-30 then?
    too thin! lol...
  19. #19 Re: Which oil do you use?
    Connecticut
    I would do that, but i've heard some people have had more valvetrain noise with thinner oils like that. Also most wear from what im aware of occurs at startup and I dont want to go too thin for that reason. Again I base this on some fact with a mix of broscience.
  20. #20 Re: Which oil do you use?
    The OP has been the champ and is running 0W-20....
    The reason you have wear is because the oil isnt thin enough.
    Couch, what sort of oil pressure are you seeing?
    Edit:
    Signature Series 100% Synthetic 0W-30 Motor Oil (AZO)
    Viscosity @ 100°C, cSt (ASTM D-445) 10.5
    Viscosity @ 40°C, cSt (ASTM D-445) 59.0
    Signature Series 100% Synthetic 5W-30 Motor Oil (ASL)
    Viscosity @ 40°C, cSt (ASTM D-445) 60.3
    Doesn't seem much different.
    But i'm new to oil.
oil
