Thread: anyone had this problem?
Results 1 to 20 of 26
  1. #1 Re: anyone had this problem?
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    The ABS check in the 04+ cars is very noticeable.
    If it was with your power steering, it wouldn't come and go, it would be a constant noise or issue. Although it wouldn't hurt to get back there and top off your fluid. The power steering is an out of sight out of mind deal with its location.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  2. #2 Re: anyone had this problem?
    SE Level Member jpdubrall84's Avatar
    LeMars, IA
    Quote Originally Posted by Durk Diggler View Post
    ^^ It may not be a direct problem with the power steering but it sounds like something is bogging the motor causing the alternator to bog as well.
    But back to the issue. Thought maybe your wheel bearings were goin out but you replaced the hubs and that wouldnt explain the dimming lights.
    When does it happen most often? Driving straight lines our turning corners? And does it do it when you just turn your wheel all the way each direction while sitting still?
  3. #3 Re: anyone had this problem?
    Apr 2011
    North Los Angeles
    Quote Originally Posted by jpdubrall84 View Post
    question not intended for me but il put in my 2 cents. This noise also happens with my car at about 2 mph. then later at around 20 or 30 (randomly) but its only for a half or full second, then again randomly when i turn the wheel to park or sometimes even to change lanes. The problem is amplified with the turn of the wheel be it slight or drastic. I have to notice if it dims out my lights at night though..
  1. Key Problem?
    By Shaun28382 in forum General Tech Discussion
    Last Post: 03-15-2011, 11:05 PM
  2. Problem
    By mwillis in forum Introductions/Noob Questions
    Last Post: 10-05-2010, 03:54 PM
  3. problem up top
    By 2000gtp1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2009, 01:00 AM
  4. Anyone else have this problem?
    By PMave in forum Audio, Security & Visual Electronics
    Last Post: 10-04-2009, 08:09 PM
  5. First Problem Need Help
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 10-19-2008, 03:30 PM
