Thread: anyone had this problem?
Results 1 to 20 of 26
  1. #1 Re: anyone had this problem?
    GT Level Member dengnath's Avatar
    but it only does it on the first turn for me.... every turn after if perfectly fine.?????
  2. #2 Re: anyone had this problem?
    SE Level Member RideMr2's Avatar
    Memphis
    I looked into this some more, I noticed something.
    Whenever this buzz happens, something is pulling current.
    My headlights dim for a second, after the buzzing stops, they brighten back up.
    I was thinking this was tied to the tcs someway, guessing, as in that system is now online, it's now ready for use.
    I don't know how to explain this though.
    I used to see a message before I got new hubs put on;
    It would say tcs active on the dic, then I would hear the buzzing noise.
    After the hubs, I don't see the message tcs active, I only hear the buzzing noise.
    I now realize this has something to do with the speed sensors coming online, being tested, not real sure how to explain it, since I don't really know what it's actually doing.
  3. #3 Re: anyone had this problem?
    SE Level Member jmt455's Avatar
    SE Michigan
    I wonder if you are hearing the ABS pump when it does the diagnostic check after each start-up.
    The ABS system performs a self-test after the vehicle gets to about 2 mph. Most drivers don't even realize it's happening...
    83 Bonneville wagon
    08 G8 Base
  4. #4 Re: anyone had this problem?
    Memphis
    Quote Originally Posted by jmt455 View Post
    Thanks for posting this.
    It's not really how far I move, I was trying to figure out 3 feet, 5 feet, one full revolution of the wheel maybe?
    It's when I actually reach a certain mph, close to 2.
  5. #5 Re: anyone had this problem?
    SE Level Member jpdubrall84's Avatar
    LeMars, IA
    Quote Originally Posted by RideMr2 View Post
    Your lights are probably dimming because when you turn youre putting strain on the power steering pump causing it to bog the motor which in turn bogs the alternator creating less electricity supply for your car briefly. and the buzz is your power steering pump being strained.
  6. #6 Re: anyone had this problem?
    Apr 2011
    North Los Angeles
    Quote Originally Posted by jpdubrall84 View Post
    wow a first straight forward answer! thank you
  7. #7 Re: anyone had this problem?
    GT Level Member starscream5000's Avatar
    Kentucky
    There is a very good chance that this is exactly what's going on with the OP's car.
    OP, is your car an '04 and up? If yes, this is probably your answer. My 2005 does the exactly same thing as described above. Funny thing though, it didn't always do this.
    This winter I had some bad wheel spin in a parking lot taking off on ice, so the TCS system was activating, then I braked and slide and the ABS activated as well, after sliding about 10-15 feet the ABS system shut itself down because it couldn't get the car back under contorl. The ABS light came on, then the TCS light as well. The HUD started popping up messages to check the ABS and TCS systems.
    Once the car was shut down and re-started the lights stayed off, but every time I take off now the TCS system kicks in momentarily after first starting up. Sometimes the HUD will says "TCS active", other times it will not. It's random, but the constant to this is that the TCS system always buzzes after first taking off now.
    I've had the battery unhooked several times since then for other tuning purposes, and it still buzzes on first takeoff now even after all settings being reset to stock. I should probably get under the car and check out the wheel sensors and clean them or replace them if needed...
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  1. Key Problem?
    By Shaun28382 in forum General Tech Discussion
    Last Post: 03-15-2011, 11:05 PM
  2. Problem
    By mwillis in forum Introductions/Noob Questions
    Last Post: 10-05-2010, 03:54 PM
  3. problem up top
    By 2000gtp1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2009, 01:00 AM
  4. Anyone else have this problem?
    By PMave in forum Audio, Security & Visual Electronics
    Last Post: 10-04-2009, 08:09 PM
  5. First Problem Need Help
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 10-19-2008, 03:30 PM
