Quote Originally Posted by monsterjam5000 View Post
Where is the resetor located and is there any way to bypass it and run power directly to the blower motor to check if the blower motor still works
Run the 2 BM wires to a battery. Black goes to negative. More than likely you have a passenger side water leak as well, also a common problem. Water leaks through the BM compartment taking the resistor and motor with it....
