Thread: Heater stopped blowing
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Heater stopped blowing
    GT Level Member gpbastard's Avatar
    Florida
    Quote Originally Posted by monsterjam5000 View Post
    Cam anyone post me a link on how to replace the blower motor and resestor. My hvac hi fuse is fine so I thought it must be the blower or resitor then but can not get this thing out and don't even see the resistor
    Here is the link for the R&R of the resistor replacement:ClubGP: Anytime you replace the BM and you have the original GM resistor it's a good idea to replace it at the same time as these have a high failure rate. The new resistor you buy at the parts store is an upgraded part and should last the life of the car....
  2. #22 Re: Heater stopped blowing
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Nice link!!
    May have saved me a few choice words when I did mine the first time. Make sure you install the water deflector or it may go out again in a few years.
    http://www.grandprixforums.net/f73/w...-fix-6961.html
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  3. #23 Re: Heater stopped blowing
    Florida
    Quote Originally Posted by Madness View Post
    Nice link!!
    Right after I replaced my BM resistor I ran my car through a car wash at SA in January in MN and the next morning I cranked it up and got nothing but smoke coming through the vents. Water from the car wash leaked through and took out the BM and resistor. Lesson learned....
  4. #24 Re: Heater stopped blowing
    Nov 2009
    A little late
    I use a Northfield, MN drive through car wash in winter and would get soap/water dripping on any passengers feet until I installed the deflector.
    MN winters are great aren't they?
  5. #25 Re: Heater stopped blowing
    Florida
    Yep, I wish it was winter all year round.....
  6. #26 Re: Heater stopped blowing
    GT Level Member GtpKo's Avatar
    Best place on Earth
    If you have climate control, the resistor pack is a $125 module. You have to be careful hard-wiring the motor as I have had smoking wires trying this. I have had more blower motor issues with my car than I all other cars I have ever owned combined! The first blower motor went out because of water getting into it and rusting out the inside. So I replaced it and thought everything was fine. It quit working again the next summer. I used a multimeter to diagnose it and found the resistor module was gone. I opened it up and it was all rusted out too. ? Thats when I messed around with hard wiring it to a plain on/off switch. So I ended up throwing in a new resistor module last winter and this summer, 3 days after getting the a/c recharged, the blower started acting wierd and quit working altogether. GRRR! I pulled the resistor pack out again and water poured out of it. Well, before I write a novel, heres a couple pics of what was causing all the trouble. A plugged drain for the core backing up water into all the electronics.
    Heater stopped blowing Attached Images
  7. #27 Re: Heater stopped blowing
    Charles City, IA
    Yup happens a lot, trail blazers have the same problem.
    SMGPFC Two Nipple General
  1. blowing air,,but not hot
    By mimi in forum General Tech Discussion
    Last Post: 12-14-2010, 02:40 AM
  2. heater not blowing hot air
    By mfowler12 in forum General Tech Discussion
    Last Post: 12-09-2010, 11:19 PM
  3. think im blowing up my trans
    By BoostJunki3 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-25-2009, 11:36 PM
  4. MAF Fuse Blowing
    By shoboy07 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 07:05 PM
  5. A/C stopped Blowing
    By RedGPGT in forum General Tech Discussion
    Last Post: 06-27-2009, 09:15 AM
