Thread: 95 GTP sunroof problem
Results 1 to 5 of 5
Threaded View
67GTO 95 GTP sunroof problem 07-17-2010, 07:14 PM
67GTO Re: 95 GTP sunroof problem 07-20-2010, 02:08 PM
iroc2 Re: 95 GTP sunroof problem 07-21-2010, 10:40 PM
67GTO Re: 95 GTP sunroof problem 07-24-2010, 05:03 PM
iroc2 Re: 95 GTP sunroof problem 07-25-2010, 09:33 PM
  1. #1 95 GTP sunroof problem
    Jun 2010
    long island ny
    On my 95 the sunroof dosen't work. So the other day I had the headliner out to recover it so I figured I would check out the sunroof to see what the problem is. I have power to the relay and switch. When you hit the button to open it you can hear the relays clicking but the rood isn't opening. Then I was tapping on and moving the relay around and the roof opened, but wouldn't close until I guess the relay made worked. So now I know I have power, the motor is good and the switch is good. I think the relay is bad. Unfortunately it is $113 at rockauto. I really don't want to spend $113 unless I have to. Is there any way I can take the relays apart to clean the contacts. Also is it possible to use regular relays in the circuit and wire them up.
  1. Sunroof still leaks...FOUND PROBLEM FINALLY
    By 99prixgt in forum General Tech Discussion
    Last Post: 05-19-2011, 09:52 AM
  2. '05 Comp G Sunroof problem...
    By speedy2 in forum General Tech Discussion
    Last Post: 10-06-2010, 10:04 PM
  3. Help sunroof problem
    By silvermistgt2002 in forum Visual/Body Modifications
    Last Post: 11-30-2009, 01:24 AM
  4. Sunroof problem?
    By 99GPGT in forum General Tech Discussion
    Last Post: 04-25-2008, 10:40 PM
  5. sunroof/moon roof problem
    By TMOTA503 in forum General Tech Discussion
    Last Post: 03-12-2008, 10:00 PM
