Thread: Heater stopped blowing
Results 1 to 20 of 27
  1. #1 Re: Heater stopped blowing
    Feb 2010
    Flint Michigan
    Where is the resetor located and is there any way to bypass it and run power directly to the blower motor to check if the blower motor still works
  2. #2 Re: Heater stopped blowing
    GT Level Member gpbastard's Avatar
    Florida
    Quote Originally Posted by monsterjam5000 View Post
    Run the 2 BM wires to a battery. Black goes to negative. More than likely you have a passenger side water leak as well, also a common problem. Water leaks through the BM compartment taking the resistor and motor with it....
  3. #3 Re: Heater stopped blowing
    Florida
    Also, There's a fuse for the #5 speed. That's probably blown as well. Open the glove box and that's where your fuses are....
  1. blowing air,,but not hot
    By mimi in forum General Tech Discussion
    Last Post: 12-14-2010, 02:40 AM
  2. heater not blowing hot air
    By mfowler12 in forum General Tech Discussion
    Last Post: 12-09-2010, 11:19 PM
  3. think im blowing up my trans
    By BoostJunki3 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-25-2009, 11:36 PM
  4. MAF Fuse Blowing
    By shoboy07 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 07:05 PM
  5. A/C stopped Blowing
    By RedGPGT in forum General Tech Discussion
    Last Post: 06-27-2009, 09:15 AM
