Thread: Change oil at what %?
Results 1 to 20 of 35
  1. #1 Change oil at what %?
    SE Level Member shawnz90's Avatar
    Kenosha
    I have a 98 Gtp bought it about 2 months ago and i did some general stuff like always when you buy a used car including an oil change and reset it. Now my oil is at 60% so i was wondering at what % most people change theres at.
  2. #2 Re: Change oil at what %?
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    0%. or if u use synthetic u can go more.
  3. #3 Re: Change oil at what %?
    GTP Level Member SuperSport's Avatar
    Michigan
    I change mine at 40%. The oil is usually pretty dark, and it has been about 3,000 miles at that time as well.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  4. #4 Re: Change oil at what %?
    GEORGIA
    u use synthetic? ive gone 5k miles on it and its not at all dark, using a mobile 1 filter.
  5. #5 Re: Change oil at what %?
    Michigan
    No. Mobil 1 10-W30
  6. #6 Re: Change oil at what %?
    every 3000 miles. that percentage thing is almost guaranteed inaccurate.
  7. #7 Re: Change oil at what %?
    GTX Level Member cerick08GP's Avatar
    I second this opinion. No way would I take it to zero on a regular basis. Changing the oil somewhere between 3-5k is best. And sure, if you run pure synthetic you can double that to 8k-10k. My GP is newer; the meter will take me out to nearly 9k if I let it!
  8. #8 Re: Change oil at what %?
    Michigan
    Quote Originally Posted by cerick08GP View Post
    My friend works at a Saturn Dealership and he sees new Saturns come in with sludged up engines because people are relying on that oil life monitor.
  9. #9 Re: Change oil at what %?
    GEORGIA
    i run pure castrol syntec with a mobile 1 filter. at 5k the oil is still very lite color.
  10. #10 Re: Change oil at what %?
    I totally believe you. 9K+ is ridiculous; I will never take my car out that far.
  11. #11 Re: Change oil at what %?
    SE Level Member 07CrimsonGT's Avatar
    Apr 2009
    Oxford, Ohio
    Shawn: I can only speak for the 04 and newer GP's, but the manual says that the change oil indicator will activate at 20%. In addition, there is a 600 mile grace period built into the system.
    In 2006, GM came out and stated relying on the oil life monitor would not void the warranty, and they encouraged folks to do so. This statement applied to taxi/police vehicles as well.
    That being said, I just did the first home oil change on my 07 at 4900 miles. The monitor was at 45%. I wanted to get the unknown dealer stuff out, and get some good Mobil 1 5w30 in there.
    Anymore, 4000-5000 miles is ok as long as you change it faithfully with quality stuff. IMO, the old 3000 miles interval is not necessary and wasteful in todays computer controlled fuel injected engines.
    Don
  12. #12 Re: Change oil at what %?
    Kenosha
    I run valvoline full synthetic and always change the filter so should i wait like 5k-ish? i read some where if it gets dirty thats good because its cleaning the motor but mines still the same color as when i put it in...
  13. #13 Re: Change oil at what %?
    Wausau, WI
    it depends if you run highway miles or city.........if city 3k, if highway 4 or 5k on standard. if synthetic run 4 or 5k city and 6-8k highway. Look at your oil when you change it. If it is black you are waiting too long.
  14. #14 Re: Change oil at what %?
    Quote Originally Posted by shawnz90 View Post
    Synthetic oils are extremely resistant to breaking down, its life more about contamination getting into the oil. Liquifire has some good points, and I totally agree to an extent. Everyone’s car and driving habits are a little different. Imo your car is getting a little on the old side and it most likely will have a LIM issues at some point. In your case, IMHO, you would be best off with a “high mileage” type dino oil and changing your oil more often. As opposed to longer intervals using synthetic.
  15. #15 Re: Change oil at what %?
    Kenosha
    The guy that had the car before me had the motor replaced because "his wife messed it up" so all new gaskets top to bottom while it was out he said he made sure of it. Not one leak lol
  16. #16 Re: Change oil at what %?
    Wausau, WI
    it depends on the oil as well.......amsoil has a product that they say needs to be changed every 25k or annually whichever comes first. I dont think I would ever wait that long, but it just goes to show that there are no set mileage or percentage rates that are 100% absolute for being a set point.
  17. #17 Re: Change oil at what %?
    GT Level Member nickbuol's Avatar
    Apr 2008
    Marion, Iowa
    I remember reading somewhere online at a site dedicated to information about oil types, manufacturers, filters, etc, where they sorted through the crap (FRAM filters for example) as well as the myths about oil (changing every 3000 miles), and it talks about how just because oil is dark in color, does not mean that it is "bad" or "used up" or whatever. Sure, that nice golden color is great, but heat alone will change the color of the oil, even if it isn't breaking down.
    With that said, I keep an eye on my mileage, I know how much highway vs. city driving I've done, and I have been doing pretty well with oil changes (100% quality synthetic oil and a good filter) about every 8,000 miles (mostly highway). The oil is dark, but not as black as non-synthetic at about 2000 miles, and the oil life gauge is at about 15% left. Oil changes are relatively cheap, so why risk it. For some people who do all city driving, that may be at 40% on the life meter, or people using regular, non-synthetic oil it may be something different.
    If you are worried about the cost, just drop 50 cents into a jar every day that you drive the car and you should have more than enough money to cover the costs when you need ot change the oil if you do it yourself...
    Currently driving a 2006 Grand Prix GT - Stock
    2000 GTP was killed by 16 year old - Nov 20, 2010 - It only had 74,000 miles, a ZZP 3" Catted Downpipe, ZZP SS PLOG, FWI, 180* T-Stat, Flipped Dog Bones, GMPP Sway Bars, G2 painted Rotors and Calipers, HUMount, and was Dexcool free!
  18. #18 Re: Change oil at what %?
    Charles City, IA
    My auto instructor has used Mobil 1 full synthetic for a long time. Changes it at 25,000 or 1 year. One of his vehicles has 300,000+ miles on it. I change mine 8-10k with amsoil, unless I have it apart again before that. lol
    SMGPFC Two Nipple General
  19. #19 Re: Change oil at what %?
    Every 3,000ish regardless of synthetic or not...
  20. #20 Re: Change oil at what %?
    Moore, Oklahoma
    My DIC is usually arounf the 50-53% range when it has 3k on it.
    I change my oil every 2,500-3,000 mile or every 4 months. Oil is cheap, motors are not...
    Shawn W. Larsen
  1. What should I change?
    By atruebudfan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2009, 02:13 PM
  2. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
  3. anyone ever change a gt to a gtp
    By e56505 in forum General Tech Discussion
    Last Post: 02-18-2009, 12:12 AM
  4. How soon do you change the oil after........
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2009, 03:56 PM
  5. s/c oil change
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2008, 05:44 PM
