Thread: How soon do you change the oil after........
Results 1 to 17 of 17
  1. #1 How soon do you change the oil after........
    Aug 2008
    SOUTH TEXAS
    I had the whole motor pulled and machined worked the block beacuse of
    broken cam bearing it had.
    I installed all new bearings(Cam,main,crankshaft) and gaskets with the repair.
    I guess just like a cam install or motor rebuild.
    How many miles or days should i drive before changing the oil?
    Wanna make sure i get all the left overs out of the engine before i go WOT.
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  2. #2 Re: How soon do you change the oil after........
    Apr 2008
    Chillin at the Beach , VA
    Your suppose to run break in oil for 500 miles. That's with no heavy acceleration or going above 55. 60 tops. Then you do your oil change with whatever oil you normally use and your good to go.
  3. #3 Re: How soon do you change the oil after........
    GT Level Member riceburner's Avatar
    Aug 2008
    denver, co
    or break it in on a dyno....mmmmmm
    '01 GTP mods: K&N intake, autolite 104's, drilled 180*, !u-bend, !EGR, ported s/c, polished heads and TB and a LOT more whine
    '99 firebird mods (1 of 6): LS1 swap, custom exhaust, LS6 IM, RA intake, and a few suspension parts
  4. #4 Re: How soon do you change the oil after........
    Apr 2008
    Well, what I said was the proper way to do it. Not that you have to. Heck when me and my friend built motors for our street rods, as soon as they were in the car running, we were balls to the wall with them. If it was built right, it stayed together, if not, you would see where the weak link was. But hey, that was just us.
  5. #5 Re: How soon do you change the oil after........
    it should run hard right away if you put it together right. yeah, take it easy for the first 100 miles or so, but why not romp on it a little. it is good for it to wear in knowing youre going to destory it everytime you get in the drivers seat.
  6. #6 Re: How soon do you change the oil after........
    SE Level Member schreurs1's Avatar
    Dec 2008
    sioux falls, sd
    make sure to use standard oil instead of synthetic for break in. thats what GM says to do on my GM circle track motors anyways. as long as the cylinders dont fit to tight you should be able to go balls to the walls fairly soon. i would granny drive it for 3-5 hundred miles and change oil. if the oil looks good and has no shavings or anything i would go WFO. jmo.
  7. #7 Re: How soon do you change the oil after........
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    I did a 30 minute "break in" by running the engine gently through the RPM-band using a good filter and conventional motor oil. Then I changed the oil and filter, ran it for several hundred miles without beating on it. Then I went back to the normal routine. That was not the GTP, but it is what I would do regardless.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  8. #8 Re: How soon do you change the oil after........
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    20 minutes @ exactly 2k RPMS. that is all that is needed for engine break in, change the oil after the 20 minutes and you are good to go.
  9. #9 Re: How soon do you change the oil after........
    Moore, Oklahoma
    How i've heard or known people to run it easy for the first 1,000 miles. Change your oil/filter the first 100, 500, 1000, 3000 miles, then go your regular cycle (which should be ever 3,000 miles anyway IMO).
    In my opinion, with the money spend on a good rebuild, i'd use the procedure above. You can't be too careful and I wouldn't want any doubt I didn't let it settle in long enough. 1,000 miles is plenty...
    Shawn W. Larsen
  10. #10 Re: How soon do you change the oil after........
    Aug 2008
    60118 NE Illinois
    ^^^ truly a waste of money, Ive always used and was taught the 20 minute/2K rule. Ive only had one engine blow up on me and that was using the 1K mile procedure, RPMS fluctuate too much during those 1K miles and the internal parts dont really make a solid pattern with these fluctuations.
    The only time actual driving is needed to break anything in is if you are also having transmission or final gear work done as well, those items need to be in motion to create their patterns.
  11. #11 Re: How soon do you change the oil after........
    GTP Level Member Scimmia's Avatar
    QCA, IA
    There's a lot of schools of thought out there. One of the most popular is the exact opposite of what you're talking about, WhiteDevil, where they say you NEED to vary your engine speed during break in to properly seat the rings.
    2001 Buick Regal LS - Almost Stock
  12. #12 Re: How soon do you change the oil after........
    beat on it. then it will be prepared for it for the rest of its life.
  13. #13 Re: How soon do you change the oil after........
    Donating Users blowfishRus6's Avatar
    g.a.
    i dont even really say drive it. fill it up with oil, crank it up and let the oil get hot ideling for about 10-15 mins. drain it, run a few quarts threw while draining to get everything out, repeat, drain, refill, drive a bit getting on it, just a short drive testing everything out, drain. all the times checking the oil for shavings, by the last time there should be no shavings of metal. then fill up with good sythentic oil that you know is gonna lubercate well then enjoy but thats just the method i would use.
    and i would still take it kinda easy on the first oil of synthetic, cause thats just me, i would go wot but not everywhere, after that oil change, which i would change after about 700-800miles, o its on
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  14. #14 Re: How soon do you change the oil after........
    Moore, Oklahoma
    Quote Originally Posted by WhiteDevil View Post
    Like I said...
    In my opinion, with the money spent on a good rebuild, You can't be too careful and I wouldn't want any doubt I didn't let it settle in long enough.
    I'd rather waste my money, and get some miles on it personally. But thats me.
    Oil is cheap, thats all I can say....
    Shawn W. Larsen
  15. #15 Re: How soon do you change the oil after........
    g.a.
    oil is cheap, dont be scared to use.
    its slow.
  16. #16 Re: How soon do you change the oil after........
    Quote Originally Posted by Iron Indian View Post
    Like I said...
    I agree with Shawn. Hell I ran 1500 miles and changed the oil every week...which turned into about 6 oil changes I think but it ran fine and still does today. When you are on a budget or something I'd rather waste 20 bucks on dino oil and a filter than another 500 on a motor rebuild IMO...Ever think that maybe you might have done something wrong on that motor rebuild that you ran the 1K miles?
  17. #17 Re: How soon do you change the oil after........
    g.a.
    yup good point
    its slow.
  1. Change Oil Soon Light
    By thermanlee in forum General Tech Discussion
    Last Post: 04-29-2009, 08:47 AM
  2. anyone ever change a gt to a gtp
    By e56505 in forum General Tech Discussion
    Last Post: 02-18-2009, 12:12 AM
  3. $pare change...what do you do with it?
    By GR8racingfool in forum Off Topic Discussion
    Last Post: 02-12-2009, 06:22 PM
  4. pulley change
    By ROTTMAN in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2009, 09:13 PM
  5. s/c oil change
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2008, 05:44 PM
