Thread: anyone ever change a gt to a gtp
Results 1 to 19 of 19
  1. #1 anyone ever change a gt to a gtp
    Aug 2008
    michigan
    i have a 97 gt 3800 that i am in the middle of changing the upper and lower intake gaskets. came across a good deal on a working supercharger. what is there to changing from efi to a supercharger?
  2. #2 Re: anyone ever change a gt to a gtp
    Hoffman/Schaumburg, IL
    The supercharged motor is still EFI(EFI=Electronic Fuel Injection)
    You need to swap the heads and up, look at 500-700 in engine parts, and another 400-800 in bolts and gaskets, and $400-500 for a tuner if you don't have some one to tune it for you.....
    Make sure to do a lot of research before attempting this
  3. #3 Re: anyone ever change a gt to a gtp
    Aug 2008
    michigan
    not worth it!
  4. #4 Re: anyone ever change a gt to a gtp
    Oh, its worth it, if you want the supercharger sound and torque.......If all you want is high Hp numbers, go turbo
  5. #5 Re: anyone ever change a gt to a gtp
    Aug 2008
    michigan
    im sure it would be one heck of a ride if i ever got it back together but i need to drive it to work tomorrow. thanks for the info
  6. #6 Re: anyone ever change a gt to a gtp
    Might as well go with a bunch of GT Bolt-Ons IMO...and beat stock GTP's...such as HV3, Stage 2 TB, 180* T-Stat, CAI, DP, U-Bend Del, PEM's/Headers, Rockers, and a PCM
    Mid to low 14's right there
  7. #7 Re: anyone ever change a gt to a gtp
    Maybe, but rockers, PEM's, HV3, and stage 2 TB is like 2/3 the cost of a full top swap, might as well do the top swap and have a low 14's car........Or turbo if you wanna go real fast...... Like I always say, though it all depends on how much go you want and how dough you got to spend
  8. #8 Re: anyone ever change a gt to a gtp
    i did mine in a day by myself. Its not hard at all. I talked to ed morad and he sent me everything i needed. I already had the basic bolt ons though which you need. Also need some tuning. I also put the HD stuff in my GT tranny. Probably spent about $650 on parts.
    Mods: L67 swap w/3.25" pulley,PRJ LL cam, 105#, FWI, 160*t-stat, 3"DP w/ubend and res delete, PEM's, autolight 103's, Magnaflow cat, 3" exhaust, PRJ Tune,PRJ Shift Kit, HD-Trans upgrade
    2008 BMW 335i Coupe.JB4,intake.Meth 17PSI
  9. #9 Re: anyone ever change a gt to a gtp
    Aug 2008
    michigan
    i only spent 1000 on the car, it immediately needed intake gaskets, came across a supercharger thought id have some fun with it, but it is still just a work car with 157thousand miles. ill just enjoy it for what it is. but i do plan on having another gp after this one goes. they are just a cool looking car that is fun to drive.
  10. #10 Re: anyone ever change a gt to a gtp
    Donating Users chico's Avatar
    Quote Originally Posted by e56505 View Post
    not worth it!
    You may think differently when you hand a Mustang GT his ass on a platter in a stoplight to stoplight race!
    04 gto stock,97 GPGT l-36 block diamond pistons ,l-32 rods ,custom comp cam grind,HS 1-7 RR, p&p heads, SS IC,SS M-90 3.5" ,4t60eHD,from Gonzales TX.
  11. #11 Re: anyone ever change a gt to a gtp
    Aug 2008
    michigan
    thats it im doin it! im keeping my 2000 gp for back and forth, and turnin my 97 into a fire breathing mustang killer! thanks guys ill be back with some updates and im sure more questions soon
  12. #12 Re: anyone ever change a gt to a gtp
    TDCRacing
    Guest
    cool!!!
  13. #13 Re: anyone ever change a gt to a gtp
    GT Level Member black98gt's Avatar
    Rochester NY
    It is deff. worth it to do a top swap, to do a top swap you need, L67 Heads, LIM, Blower(obviously), TB, brackets for alt., idler pullies, coils, L67 fuel rails, vac. line re-routing, I think you need wiring(Not 100% sure) for new sensors, re-tuned PCM, L67 fuel injectors, L67 harmonic balancer(crank pulley) colder plugs(104's would be perfect). And all the gaskets(head,valver,SC).
    Right there, you're looking at around 600-700 dollars. The stock GT tranny is fine, if you dont beat on the car. The 4t65e is the stock GT tranny, 4t65e-HD is the GTP tranny. The GTP tranny is a heavier duty tranny, hence the HD. In my opinion, its deff. worth doing a top swap.
  14. #14 Re: anyone ever change a gt to a gtp
    GT Level Member YoungGTP's Avatar
    Aug 2008
    Iowa
    smoking a mustang and laughing the whole time is more then worth it. mustang guys just yell at you and say "thats a slow grand prix" then the light turns green and they wet there pants. you'll have a blast
    -98 GTP Thunderstorm
    Cai, 3.5 press on pulley, NGK TR6's, 3" to 2.5" exhaust, thrush glasspacks, drilled 180 t-stat soon-overkill pcm, fully ported sc, N* TB, and LQ4 MAF, Future- Full I/C, XP cam, s&s headers
  15. #15 Re: anyone ever change a gt to a gtp
    Bloomington, IL
    ive done it. I have a 2001 Grand PRix GT. look on zzperformance.com and go under engine. there is a complete listing of needed parts. i payed alittle extra and had it installed the right way. this way if there are problems i will be able to have installer fix it. nothing is wrong yet. car runs great. got about 75 whp out of it. makes for a awesome sleeper. get al ot of weird looks from debadge gtp owners and also awesome kill stories with GTP's. I also got the 4t65e shift kit. car shifts much harder and firmer/faster. Lucie776@msn.com if you have any questions.
  16. #16 Re: anyone ever change a gt to a gtp
    Nov 2008
    edmonton
    i am going to swap a gt to gtp have 2 97 the gtp is out of province and won't pass and the gt needs head gaskets. looking for info on what parts must be changed. i am leaning towards a cradle swap but want to know what else has to be changed like the wiring harness. i know the pcm is a must be any info from someone with experience would be greatly apreiciated
    thanks
    luke
  17. #17 Re: anyone ever change a gt to a gtp
    Nov 2008
    edmonton
    got the engines swapped hoping to finish it up today
  18. #18 Re: anyone ever change a gt to a gtp
    12s on street tires in a FWD car is usually pretty fun. youll stomp on a lot of cars, but youll take a digger when you get lined up with something beefier (terminator, lsx, etc.).
    im getting there on a rocker setup. im liking it so far. just finished my alky setup tonight. im pumped.
  19. #19 Re: anyone ever change a gt to a gtp
    Nov 2008
    edmonton
    finished everything up found out i did not need to change the dic for boost gauge and the only change i needed for performance shift was the shift knob
    it was very easy to do but then again i had to 97s and they were complete
  1. Change Oil Soon Light
    By thermanlee in forum General Tech Discussion
    Last Post: 04-29-2009, 08:47 AM
  2. Impossible......to change
    By blackheart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2008, 07:26 AM
  3. How do you change you fog lights
    By mrkingkong in forum Off Topic Discussion
    Last Post: 08-11-2008, 03:26 PM
  4. How to Change Plugs
    By mainecrab in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-29-2008, 07:09 PM
  5. So who here thinks Trannyman should change his profile?
    By Zef_66 in forum Off Topic Discussion
    Last Post: 02-26-2008, 09:39 PM
