Thread: Installed Intercooler.. Breather or not??
Results 1 to 20 of 22
  1. #1 Installed Intercooler.. Breather or not??
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Just installed my "old school" INTENSE intercooler core. This particular model does not have provisions for normal PCV function. I already have a valve cover breather, so went and installed it last night.
    For those of you who have ran an intercooler and used a breather, how much did you have to modify your MAF table to adjust for the vacuum leak and the lean conditions at idle/cruise? I was adjusting my MAF table quite a bit last night but still seeing very high long term fuel trims.
    Any help/recommendations related to this are welcome. Thanks!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: Installed Intercooler.. Breather or not??
    May 2008
    Schuyler, NE
    If the intercooler doesn't have a pcv function, it is blocking the pcv. In that case, there is no vacuum leak. If your maf is way off, you probably have a vacuum leak somewhere around the plate or between them.
  3. #3 Re: Installed Intercooler.. Breather or not??
    Mar 2014
    Cincinnati, OH
    I was wondering if that was the case, but I sealed everything up really carefully and used quite a bit of RTV/sealant when installing the intercooler core, and then the blower.. Not saying it isn't possible, but I just would be surprised I guess. maybe I can spray something around the plates to see if I see any air/bubbles leaking.
    Would the valve cover breather by itself (as the only vacuum leak) need that much MAF tweaking to offset it???
    2002 GTP sedan:
  4. #4 Re: Installed Intercooler.. Breather or not??
    hangover park IL
    if that core is one of the non passage equipped cores...then it has no PCV or fresh air pathways to the crankcase, at which point the VC breather isn't a vac leak. the issue arises since many cores have PCV passage provisions but lack the fresh (metered) air path
    ~James~ Psychotic Gearhead
  5. #5 Re: Installed Intercooler.. Breather or not??
    May 2008
    Schuyler, NE
    I've never tuned a car with just a breather. I am guessing you would probably see inconsistent results due to the nature of the pcv valve. But that should have nothing to do with your situation.
    Spray starting fluid around the plate while the car is running and listen for changes in the idle.
  6. #6 Re: Installed Intercooler.. Breather or not??
    Mar 2014
    Cincinnati, OH
    Appreciate the info!
    Here is the exact replica of the core I have. It has a spot for the rear PCV, but none allowing the "inlet" when the car is in vacuum:
    http://www.intense-racing.com/images/ic_600.jpg
    Trying to decide if I actually need the valve cover breather for this intercooler core or not.
    2002 GTP sedan:
  7. #7 Re: Installed Intercooler.. Breather or not??
    hangover park IL
    the front hole is for the fresh air. but since you likely have a TB adaptor plate, it may not be plumbed at the fresh metered air passage to the TB flange.
    gen5 guys can easily run a hose from post maf/pre tb to the OEM fresh air nipple....that gen3's don't have (but you can add)
    btw please tell me you pressure tested the core? a lot of em cracked n developed leaks
  8. #8 Re: Installed Intercooler.. Breather or not??
    hangover park IL
    nm I see yer still stock tb with some spacer...make sure the spacer has the fresh air passage/hole and you wont need a breather if that core has the front and rear PCV holes
  9. #9 Re: Installed Intercooler.. Breather or not??
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by Turbocharged400sbc View Post
    yep, stock throttle body (ZZP ported Stage 2 though) and the spacer does have the passage for fresh air. Maybe I will pull the breather off this evening and try it out.
    Can't say I pressure tested the core, but I did run water through it and it didn't leak (not at high pressures though).. Fingers crossed I guess?!?!?!
    So that port on the top left side in the pic (close to the 90* coolant inlet elbow) serves as a proper supply location for clean air into the crank case??
    2002 GTP sedan:
  10. #10 Re: Installed Intercooler.. Breather or not??
    GT Level Member mguzzo's Avatar
    Buffalo NY
    You can pull fresh air from behind the MAFF and route it to the front valve cover. Then you'll have metered air supplying the PCV function.
    I used a stock oil cap extended and drilled a hole with a 3/8" push connector, and tapped from behind my MAF sensor.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  11. #11 Re: Installed Intercooler.. Breather or not??
    Mar 2014
    Cincinnati, OH
    Thanks for the pic. That is actually the exact plan I had next, if my breather was still causing issues. Going to put the oil cap back on and remove the breather first and re-tune to see if the crazy fuel trims subside.
    2002 GTP sedan:
  12. #12 Re: Installed Intercooler.. Breather or not??
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    what are you gonna do for the rear pcv?
    btw: that is the same way i had my front pcv working, except i tapped my tb and ran it there.(2000)
  13. #13 Re: Installed Intercooler.. Breather or not??
    Kemmerer, Wyoming
    I had the same thing mguzzo had except I used a shrader valve in the vacuum line. I ran the line to the evap port on the throttle body. only reason I did that on mine was because I had too much crank case pressure and oil was coming out the dipstick tube. it doesn't sound like that is what is happening to you, but it might help your situation with the non functioning pcv.
  14. #14 Re: Installed Intercooler.. Breather or not??
    Quote Originally Posted by SgtMarshal View Post
    being you had one of ed's ic's and i own it now, and i had to clear the rtv out of the pcv holes in th ecore. maybe thats how you had crank case pressure.
  15. #15 Re: Installed Intercooler.. Breather or not??
    Kemmerer, Wyoming
    being you had one of ed's ic's and i own it now, and i had to clear the rtv out of the pcv holes in the core. maybe that's how you had crank case pressure.
    I knew this, I just didn't want to fix it the right way. I eventually got it right and took the pcv thingy off.
  16. #16 Re: Installed Intercooler.. Breather or not??
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by JamesIvey24 View Post
    Rear PCV will still function like stock for when crankcase pressure goes positive.
    Was mainly concerned about when the crank case is seeing vacuum, making sure the port in the throttle body still has a clear path to provide clean air to the crank case (and if not, the breather route or the vacuum line from post MAF to valve cover oil fill location).
    2002 GTP sedan:
  17. #17 Re: Installed Intercooler.. Breather or not??
    Mar 2014
    Cincinnati, OH
    Just removed the breather and installed the stock oil filler cap. Reset fuel trims with HP-Tuners and fired the car up. Checked and the oil cap is not pulling strong vacuum, which should be a good sign and that the stock PCV setup is operating as intended...
    my fuel trims are still maxed at +16.4 with a lean idle. I can't hear any vacuum leaks and I was careful when applying the RTV when sealing up the intercooler core. Any other ideas on what I could be missing??
    2002 GTP sedan:
  18. #18 Re: Installed Intercooler.. Breather or not??
    spray it down with carb cleaner +16 is a vac leak
  19. #19 Re: Installed Intercooler.. Breather or not??
    Mar 2014
    Cincinnati, OH
    Yep, carb cleaner time it is..
    2002 GTP sedan:
  20. #20 Re: Installed Intercooler.. Breather or not??
    hit the egr tube if you got one, or the block off plate, the tb gasket, injectors, lim and blower. and your vac lines.
  1. Coolant leak when Intercooler is installed, Help!
    By Beatdowncity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2015, 07:00 PM
  2. Using a breather with an intercooler
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 10-04-2014, 06:38 PM
  3. Coils, icm postion after intercooler installed
    By samuelcb409 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2012, 12:53 AM
  4. Intercooler installed but car won't start?
    By Pure2sin in forum General Tech Discussion
    Last Post: 06-03-2011, 10:50 PM
  5. Installed a Gen V SC onto Gen III Intercooler?
    By geforcextreme in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2010, 11:01 PM
