Thread: Installed Intercooler.. Breather or not??
Results 1 to 20 of 22
  1. #1 Re: Installed Intercooler.. Breather or not??
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    what are you gonna do for the rear pcv?
    btw: that is the same way i had my front pcv working, except i tapped my tb and ran it there.(2000)
  2. #2 Re: Installed Intercooler.. Breather or not??
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by JamesIvey24 View Post
    Rear PCV will still function like stock for when crankcase pressure goes positive.
    Was mainly concerned about when the crank case is seeing vacuum, making sure the port in the throttle body still has a clear path to provide clean air to the crank case (and if not, the breather route or the vacuum line from post MAF to valve cover oil fill location).
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  1. Coolant leak when Intercooler is installed, Help!
    By Beatdowncity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2015, 07:00 PM
  2. Using a breather with an intercooler
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 10-04-2014, 06:38 PM
  3. Coils, icm postion after intercooler installed
    By samuelcb409 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2012, 12:53 AM
  4. Intercooler installed but car won't start?
    By Pure2sin in forum General Tech Discussion
    Last Post: 06-03-2011, 10:50 PM
  5. Installed a Gen V SC onto Gen III Intercooler?
    By geforcextreme in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2010, 11:01 PM
