Rear PCV will still function like stock for when crankcase pressure goes positive.
Was mainly concerned about when the crank case is seeing vacuum, making sure the port in the throttle body still has a clear path to provide clean air to the crank case (and if not, the breather route or the vacuum line from post MAF to valve cover oil fill location).
