Thread: Some more top swap questions! Yay!
Page 65 of 71 FirstFirst ... 15556364656667 ... LastLast
Results 1,281 to 1,300 of 1411
  1. #1281 Re: Some more top swap questions! Yay!
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    If scotty took out that much timing and he's still seeing knock is it possible it's false? Yeah I was wondering what N/A cars have stock I thought they had like 20+. I'm surprised he was only seeing 4* I would have thought it would have been more.
    Sent from my SM-S902L using Tapatalk
    2012 F150 STX
    - Gonna be a race truck
  2. #1282 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Ok scotty check your email!!
    Sent from my LG-D851 using Tapatalk
  3. #1283 Re: Some more top swap questions! Yay!
    its 21 wot lol
    once you add boost it cant be that high. his kr is real, it needs a bit more help. maybe the maf, or a degree timing pulled. stock timing can reach like 16.5, and that maybe to high.
  4. #1284 Re: Some more top swap questions! Yay!
    mail sent. dont clear the fuel trims, do a partial flash. this way you dont reset the fuel trims. only time i clear the trims is if a i do a fueling change.
  5. #1285 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok and so did you just lower timing by two on the whole table or just certain spots? If just certain spots how do you know where to take it from?
  6. #1286 Re: Some more top swap questions! Yay!
    a page or so back i posted a pic of the timing folder open and the bottom area highlighted. once highlighted right click and the window opens up for you to select add or subtract.
  7. #1287 Re: Some more top swap questions! Yay!
    Oct 2015
    So its just always those 4 bottom rows?
  8. #1288 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    it's really just the bottom row, but with all the possible transitions, it's good to do more.
  9. #1289 Re: Some more top swap questions! Yay!
    Quote Originally Posted by SgtMarshal View Post
    that covers from 3200 rpm to 6400. where most kr starts on my cars, it takes a degree out of each cell.
  10. #1290 Re: Some more top swap questions! Yay!
    Oct 2015
    Ahhhh ok got it! Well im at work now so i cant flash it till tonight but i will! Thanks
  11. #1291 Re: Some more top swap questions! Yay!
    it should be better. give it a few days, scan all the stuff i told you to in the e mail, then we can see where your at and fine tune it as needed.
    iirc your ait was still kinda cold, like 70 degrees? once that gets hotter out you'll need to work on it more maybe.
    cold air is gods intercooler. once it gets hot out the air gets thinner and with hotter intake temps kr happens. why its always best to tune in the worst heat and humidity possible.
  12. #1292 Re: Some more top swap questions! Yay!
    Apr 2012
    Dayton, OH
    I really like this thread, now you guys make me want to get DHP.
    2012 F150 STX
  13. #1293 Re: Some more top swap questions! Yay!
    Oct 2015
    Its pretty cool lol. Ya and summers in az are in the 120s it was about 92 when i was running the scan
  14. #1294 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    hp tuners is so much more intuitive, and easier to use. also more expensive.
  15. #1295 Re: Some more top swap questions! Yay!
    for the price, dhp is just fine.
  16. #1296 Re: Some more top swap questions! Yay!
    Oct 2015
    Just curious what other ways are there to reduce kr other then just pulling timing
  17. #1297 Re: Some more top swap questions! Yay!
    it comes down to a balance of fuel via the maf or timing. you dont want to flood it with gas. but you also dont want it too lean.
    depending on where your ltft are wot you may not need to mess with the maf file at all.
  18. #1298 Re: Some more top swap questions! Yay!
    Oct 2015
    I think the last scan they were locking in at -3.9
  19. #1299 Re: Some more top swap questions! Yay!
    Donating Users timboku's Avatar
    Montgomery, IL
    How much race gas is still in the tank....???? When you go back to 91 your tune will be messed up again if you are changing fueling..I'd wait till all that gas is out unless your gonna be running race gas
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  20. #1300 Re: Some more top swap questions! Yay!
    Oct 2015
    I filled it all the way up with 91 when it had 1 gallon of 93 left in it so it's pretty evend out at this point
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
