Thread: Some more top swap questions! Yay!
Page 55 of 71 FirstFirst ... 545535455565765 ... LastLast
Results 1,081 to 1,100 of 1411
  1. #1081 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    Rough idle won't cause kr. I guarantee my xp cam with 130 lb springs shakes more than a top swapped car and I've had my idle set to 750 rpm before
  2. #1082 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Like when im pulling in to a parking spot off the gas of course my rpms drop really low probably around 350 or 400 and then they will shoot back up. (this was happening before swap as well)
    Sent from my LG-D851 using Tapatalk
  3. #1083 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Yea if it's not running properly it's going to cause a vibration or shake while idling unless you have a cam which you don't
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  4. #1084 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    Quote Originally Posted by suitercrew View Post
    Sounds like a vacuum or exhaust leak
  5. #1085 Re: Some more top swap questions! Yay!
    Oct 2015
    Are there any other vac lines other than whats connected to the sc
  6. #1086 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Just curious where did you have the new o2 sensor bung welded in at?
  7. #1087 Re: Some more top swap questions! Yay!
    Donating Users timboku's Avatar
    Montgomery, IL
    Still say exhaust or vac. Leak, this will effect so much...can tuned for a top swap is pretty basic...and with headers on a stock pulley you have enough mods for a top swap..cross over, egr pipe, spray all vac lines while scanning, tb, exhaust manifolds, etc.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  8. #1088 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok so i just got another pending code for cylinder misfire on the same cylinder any ideas what it might be i already swapped the wire im gonna change out the icm and coil pack now
  9. #1089 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Idk dude I hope all that KR didn't put a hole in the piston or something I'd go to harbor freight and get that cheap bore scope or whatever to look down in the cylinder
  10. #1090 Re: Some more top swap questions! Yay!
    pull that plug already. maybe its cracked, some thing simple.
  11. #1091 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok i will check plug!!
  12. #1092 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Post a picture of cylinder 3 plug
  13. #1093 Re: Some more top swap questions! Yay!
    Oct 2015
    I tried my camera wouldnt focus on it but as far as looks go i looked for even the smallest crack and didnt see anything. If anything the plug looked cleaner then the one from cylinder 5 i swapped it with so i would know if it was just a really sneaky plug
  14. #1094 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok so let me ask the icm and coil packs are the same on the l36 and l67 right?
  15. #1095 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Does it look whiter?
  16. #1096 Re: Some more top swap questions! Yay!
    Oct 2015
    I just switched over the icm and coil packs from my l36 and i just started it up and im getting a loud popping. Idk from where because its loud so i shut it off real quick
  17. #1097 Re: Some more top swap questions! Yay!
    Montgomery, IL
    Did you hook up wires correctly?
  18. #1098 Re: Some more top swap questions! Yay!
    Montgomery, IL
  19. #1099 Re: Some more top swap questions! Yay!
    Oct 2015
    Ya i dif cross those stupid wires.. I think i need to get some sleep lol
  20. #1100 Re: Some more top swap questions! Yay!
    Oct 2015
    Butt now im still getting a pending cylinder 3 missfire after switching that one plug to cylinder 5 and replacing the icm and coil pack. What else fuel injector?
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
