Thread: Some more top swap questions! Yay!
Page 66 of 71 FirstFirst ... 16566465666768 ... LastLast
Results 1,301 to 1,320 of 1411
  1. #1301 Re: Some more top swap questions! Yay!
    -3.9 is rich. it could be leaned out some. but id let it go for now, make sure they are learned fully. im no fan of the quick learning. i let it go days to a week before making another fuel change.
  2. #1302 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Ok sounds good
    Sent from my LG-D851 using Tapatalk
  3. #1303 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    another thing I remembered, when you take a scan, do not turn your ac on or it will skew the scan data. I don't know why, but I remember hearing that someplace.
  4. #1304 Re: Some more top swap questions! Yay!
    Oct 2015
    Uhh ooo lol
  5. #1305 Re: Some more top swap questions! Yay!
    Oct 2015
    Hey scotty i just sent you my latest scan!
  6. #1306 Re: Some more top swap questions! Yay!
    you need some fuel up top. and the large kr was when it dropped form 4 th to 2 nd and most of the rest of the kr was from a down shift too.
    ill add some fuel up top for ya, and send it back in a few.
  7. #1307 Re: Some more top swap questions! Yay!
    Oct 2015
    Is that normal? Or i guess what does fuel have to do with downshifts?
  8. #1308 Re: Some more top swap questions! Yay!
    i think your tranny is angry at you. you can see early in the scan its only a blip at 0.8 kr at a down shift, but that one time you look to have really hammered it from od and it dropped to 2 nd, causing that sh it storm of 7ยบ kr.
    put the car in 3 rd before mashing it like that, it should help.
    and you got mail.
  9. #1309 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok cool also did you notice the ltft were locking in at a different number when the bigger kr started happening?
  10. #1310 Re: Some more top swap questions! Yay!
    yeah, it went lean. why i added some fuel up top. keep in mind, when ltft is a neg number thats rich, once it goes pos, its leaning out on you.
    your one shift didnt happen till 6000 rpm too. should be closer to 5600/5800. thats a sloppy shift. a shift kit should help with that. can also tun up the line pressure a bit more too.
    add boost to your scan too. be nice to see how much your making.
  11. #1311 Re: Some more top swap questions! Yay!
    Oct 2015
    I have a transgo shift kit
  12. #1312 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok ill flash the new new one when i go on break
  13. #1313 Re: Some more top swap questions! Yay!
    eek....that sucks.
    let me go check your shift points in the tune.
  14. #1314 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok thats why i was asking if you could look into if he had it set up for the 3.29 gears cause ive been thinking my shift points were really high and even though it should shift at 5800 if he has the 2.93 gears in there it would shift late. Luckily atleast i have those 90# springs in
  15. #1315 Re: Some more top swap questions! Yay!
    you could run it that high with good springs, but your tranny dont seem to like it.
    the trans file is changed for sure. if it was the wrong gears it would shift all funky. like not right at all.
  16. #1316 Re: Some more top swap questions! Yay!
    Oct 2015
    So is the tranny going or is it just tempermental?
  17. #1317 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    Overkill has it shift at 6200 with the 90's.
  18. #1318 Re: Some more top swap questions! Yay!
    Quote Originally Posted by SgtMarshal View Post
    it got 7ยบ at the shift, @ 6000. trying it lower cant hurt. kr started and left a few cells at/after the shift while he was still in the gas wot.
    it was a 4 th to 2 nd down shift, mashed. id think tranny caused that.
    all his other down shifts were a blip of 0.8 or less. kinda normal. i get that too.
  19. #1319 Re: Some more top swap questions! Yay!
    Oct 2015
    Ya idc lower shift points!!
  20. #1320 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    I should have said that 6200 was fine for the valve train, but the transmission might not like it
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
