Thread: Some more top swap questions! Yay!
Page 67 of 71 FirstFirst ... 17576566676869 ... LastLast
Results 1,321 to 1,340 of 1411
  1. #1 Re: Some more top swap questions! Yay!
    Donating Users timboku's Avatar
    Montgomery, IL
    How are the trans and engine and dog bone mounts? This can be atributing to your hard shifts and kr as well.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  2. #2 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    I just replaced all the mounts about a month before i did the swap.
    Sent from my LG-D851 using Tapatalk
  3. #3 Re: Some more top swap questions! Yay!
    Oct 2015
    The next scan i do ill put booost on there. I just saw about 7.2 lbs on tapp though
  4. #4 Re: Some more top swap questions! Yay!
    thats ok boost. i was down to 6.5 on the stock pulley, but i got rockers and heads. they let it flow better.
    hows it feeling now since the timing fix?
  5. #5 Re: Some more top swap questions! Yay!
    Oct 2015
    Well it feels better from the last timing fix i havent flashed the latest yet though cause my break got cut short and i was in a rush so i will be flashing the latest tonight.
  6. #6 Re: Some more top swap questions! Yay!
    the last one with the extra fuel im sure you wont feel, other then killing the little kr you had randomly. and the ltft locking in closer to 0.0.
    if you see 2 or more degrees of kr, let off asap. a blip at a down shift or up shift is one thing, larger spikes are no good.
  7. #7 Re: Some more top swap questions! Yay!
    Oct 2015
    Sounds good! Thanks for all your help scotty!! By the way so when you add fuel technically all your doing is raising the values in the maf table?
  8. #8 Re: Some more top swap questions! Yay!
    yup.
    the range breaks down like this.
    idle 1000- 3000
    cruise 3100-6900
    wot 7000- 12500
  9. #9 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok thats good to know!
  10. #10 Re: Some more top swap questions! Yay!
    print out that manual i sent ya, makes good crapper reading.
  11. #11 Re: Some more top swap questions! Yay!
    Oct 2015
    Will doo
  12. #12 Re: Some more top swap questions! Yay!
    Oct 2015
    How can i turn tcs off in dhp?
  13. #13 Re: Some more top swap questions! Yay!
    i just went looking for it, its turned off in your bin already. you can find it in.
    fuel, then torque management, then "traction disable injectors. "
  14. #14 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok cool and so that takes care of not having the boost pressure solenoid or whatever right?
  15. #15 Re: Some more top swap questions! Yay!
    that you just delete the code. im sure its deleted or the cel would be on for it. iirc all that does is keep it from boosting in reverse.
    the tc disable should make your tc no longer work. like you dont have to push the tc off button no more if you have one.
  16. #16 Re: Some more top swap questions! Yay!
    Oct 2015
    Even if the light is off as if tcs was still active it will actually he off righ
  17. #17 Re: Some more top swap questions! Yay!
    button off /on its turned off full time now in the tune.
    see if the wheels spin tc off. dirt or grass works well.
  18. #18 Re: Some more top swap questions! Yay!
    Oct 2015
    Haha ok just checking thanks scotty
  19. #19 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    I don't think P0243 will set the light. it never did for mine.
  20. #20 Re: Some more top swap questions! Yay!
    Oct 2015
    Does anyone ever mess with the boost ramp rate or anything else in the sc section
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
