Thread: Some more top swap questions! Yay!
Page 68 of 71 FirstFirst ... 18586667686970 ... LastLast
Results 1,341 to 1,360 of 1411
  1. #1341 Re: Some more top swap questions! Yay!
    i dont play with that at all.
  2. #1342 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Ok then i wont touch it either haha
    Sent from my LG-D851 using Tapatalk
  3. #1343 Re: Some more top swap questions! Yay!
    Oct 2015
    So i finally got the trims to relearn on my way home tonight so in the a.m ill take a scan and beat on it a little bit and let you guys (scotty) know how it goes!!
  4. #1344 Re: Some more top swap questions! Yay!
    Oct 2015
    I found some 42.5# green top injectors for 100$ would these work good for the e85 conversion?
  5. #1345 Re: Some more top swap questions! Yay!
    Donating Users timboku's Avatar
    Montgomery, IL
    Quote Originally Posted by suitercrew View Post
    Yes, make sure they are ev1 connectors
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  6. #1346 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    when/if you put in the 42.5 lb injectors, you will need to change the injector flow rate. basically what you do is find the percent difference between the stock injectors and the ones you are putting in.
    42.5's should be big enough for E85 on a supercharged car.
  7. #1347 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok ya i figured id have to do some research on tuning for them. Another question if i was just going for a lower hp build can you keep stock fuel pump or at what hp point do you need to upgrade?
  8. #1348 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    I am still running a stock fuel pump, but have a rewire kit in. at one point I had a 2.9 pully with full size intercooler, ported heads, XP cam and a few other things, so I would say to start with a rewire, and go from there. when the need arises, I plan on grabbing a walbro 255 from wbodystore, it's like 100 bucks and comes with everything you need. I am considering going to E85 as well, and when I do, the stock fuel pump probably wont flow enough.
  9. #1349 Re: Some more top swap questions! Yay!
    Oct 2015
    So injectors, rewire, and tune is all i should need?
  10. #1350 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok scotty just took it for a test drive so if i get on it in first or second gear i have 0kr sometime a blip of .2 or something but the downshifts are still terrible mashing it in 4th and it downshifting to 2nd results in 6-8 degrees of kr
  11. #1351 Re: Some more top swap questions! Yay!
    Oct 2015
    Also my stft locks in at 0 and ltft locks in a -11
  12. #1352 Re: Some more top swap questions! Yay!
    theres a chance the trims were not learned fully when we added fuel.
    being -11, id set the maf back to stock and start over,
    open your bin, got to the maf folder, the top file, right click it, import stock maf file. save on exit. its back to stock where we started.
  13. #1353 Re: Some more top swap questions! Yay!
    Oct 2015
    What about downshift kr?
  14. #1354 Re: Some more top swap questions! Yay!
    why are you down shifting it? you want to kill the tranny?
  15. #1355 Re: Some more top swap questions! Yay!
    Oct 2015
    Well not particularly but shouldnt i be able to mash on it without so much of a kr issue or is that normal?
  16. #1356 Re: Some more top swap questions! Yay!
    when it drops a gear and kicks down when you floor it, a blip is some what normal, 7ยบ is not. a blip is less then a degree in my book. like a 0.6 kr for one cell.
  17. #1357 Re: Some more top swap questions! Yay!
    Oct 2015
    Well is that an issue with the tcc?
  18. #1358 Re: Some more top swap questions! Yay!
    Oct 2015
    Also i can import the stock maf table but the maf positive and maf negative tables are different too. Do i put these back to stock as well?
  19. #1359 Re: Some more top swap questions! Yay!
    that i dont know, something in the tranny may not be happy.
    did you ever scan for kr before the topswap? if it did that before hand, its the tranny.
    or maybe the down pipe hitting the sway bar.
  20. #1360 Re: Some more top swap questions! Yay!
    Oct 2015
    I did scan for kr before the swap. I would see a couple degrees of kr at wot all the way through the rpm range it never peaked it was just steady kr
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
