Thread: Some more top swap questions! Yay!
Page 16 of 71 FirstFirst ... 614151617182666 ... LastLast
Results 301 to 320 of 1411
  1. #1 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Is it ok if i put a very small amount of oil on the seal and valve stem?
    Sent from my LG-D851 using Tapatalk
  2. #2 Re: Some more top swap questions! Yay!
    id only lube the stem, if that even. you want the bottom dry so its a good seal and holds it tight. if you got them plastic caps they slide on pretty easy.
  3. #3 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Yeah or assembly lube it won't hurt.
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  4. #4 Re: Some more top swap questions! Yay!
    Oct 2015
    How freely will the valve move with the seal on?
  5. #5 Re: Some more top swap questions! Yay!
    Oct 2015
    I used the socket i put oil on it and it took me 10 minutes of applying a lot of pressure to get it on and i dont even think its on all the way i dont understand why this is so hard
  6. #6 Re: Some more top swap questions! Yay!
    it will hold the valve in pretty much. once its running the stem gets oiled.
  7. #7 Re: Some more top swap questions! Yay!
    i had a round ring indented in my palm lol tap it on there.
  8. #8 Re: Some more top swap questions! Yay!
    Oct 2015
    Like this lol
  9. #9 Re: Some more top swap questions! Yay!
    yup lol
  10. #10 Re: Some more top swap questions! Yay!
    Oct 2015
    So now i got the seals on and i went to put my new l76 springs on and it doesnt look like there wide enough to go over the valve guide...
  11. #11 Re: Some more top swap questions! Yay!
    they fit
  12. #12 Re: Some more top swap questions! Yay!
    Oct 2015
    Also im ordering all my parts and was gonna get new plugs should i go with the autolite 103s or 104s?
  13. #13 Re: Some more top swap questions! Yay!
    104's are working good for me.
  14. #14 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok cool!
  15. #15 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok so half my valve springs dont fit, the ones that do ate a very tight fit but its like other valve guides are slightly bigger not that they look bigger but i took one spring that wouldnt fit on 2 guides then put it on another and it fit perfectly sooo this sucks.
  16. #16 Re: Some more top swap questions! Yay!
    flip the spring over maybe?
  17. #17 Re: Some more top swap questions! Yay!
    Oct 2015
    Lol yah i already checked that haha. So the question is can i try to bend the bottom of the spring out just a hair so it will fit or take a grinder ore something and shave a little of the inside of the spring seat?
  18. #18 Re: Some more top swap questions! Yay!
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by suitercrew View Post
    Do you have stock springs, or bigger springs?
  19. #19 Re: Some more top swap questions! Yay!
    pics. the springs should fit.
  20. #20 Re: Some more top swap questions! Yay!
    Oct 2015
    Im trying to install l76 springs
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
