Thread: Some more top swap questions! Yay!
Page 60 of 71 FirstFirst ... 1050585960616270 ... LastLast
Results 1,181 to 1,200 of 1411
  1. #1181 Re: Some more top swap questions! Yay!
    May 2012
    Where winter never ends
    Local guy.
    2000 Regal - Winter Beater
  2. #1182 Re: Some more top swap questions! Yay!
    May 2012
    He has tons of em layin' around. Think hes up to 350 a pop now
  3. #1183 Re: Some more top swap questions! Yay!
    Quote Originally Posted by suitercrew View Post
    Who did you touch to get that deal!?
    Sent from my LG-D851 using Tapatalk
    lmao ^^^^^
    my engine was free. touched no one.......
  4. #1184 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    To bad your so far from me lol
  5. #1185 Re: Some more top swap questions! Yay!
    Oct 2015
    How many volts should be going to the injectors with engine off key on. I tested cylinder 3 injector and it was at 5.9 volts but so was cylinder 5
  6. #1186 Re: Some more top swap questions! Yay!
    Oct 2015
    Changed plug back to stock heat range and not even the slightest difference in misfire count. I have a spare icm harness im going to swap out next. Its a long shot but when i did first start it i forgot to plug it in all the way and the motor died cause it popped out. Maybe something got shorted since it was loose?
  7. #1187 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Why won't you just do a compression test? It's easy to do
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  8. #1188 Re: Some more top swap questions! Yay!
    Oct 2015
    The compression test is on its way i decided to just take a day off and stop messing with stuff. I have thursday off and my dad already has a tester so on thursday im just going to borrow his.
  9. #1189 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Oh gotcha I don't know how you wait the anticipation would kill me lol
  10. #1190 Re: Some more top swap questions! Yay!
    Oct 2015
    It killed me the first couple days but ive thought it out. I just purchased a dhp tuner off a member here so that i can atleast get this kr to 0 so i dont cause anymore damage. I figure if its a chipped piston the damage is already Done and ill probably just drive it with a small compression leak. If its a not sitting valve ill pull the head and have a valve job done at a shop this time.
  11. #1191 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    with the dhp you can adjust your maf sensor and lower timing, those two things together will make a big difference.
  12. #1192 Re: Some more top swap questions! Yay!
    Oct 2015
    Thats the plan! Even though i have no idea how to do any of that haha
  13. #1193 Re: Some more top swap questions! Yay!
    you got help, dont sweat it.
  14. #1194 Re: Some more top swap questions! Yay!
    Oct 2015
    Well i appreciate all the help from everyone! 1200 posts later and i almost have a fully running topswap lmao. Does there happen to be a dhp thread for beginners i tried googling it and found a lot of dhp threads but not one for beginners.
  15. #1195 Re: Some more top swap questions! Yay!
    https://www.dropbox.com/sh/npa8brtuzoq3qps/jqYuBP0cv- your new bible for tuning. bottom folder "Tuning Guides and worksheets"
    theres jerrys tuner hand book. look for that in there.
    pm me your email, ill email you another one called "tuner rev." it reads a lot like jerrys but does not use the eddies table modifier thingy. it teaches you how to make adjustments on your own.
    ive used that eddies program, its good for when you dont trust your self yet.
  16. #1196 Re: Some more top swap questions! Yay!
    Oct 2015
    I was reading througg jerrys guide and made it 3 pages and now my mind is all twisted and confused lol. Hopefully i can find some youtube videos haha
  17. #1197 Re: Some more top swap questions! Yay!
    you likely wont find jack on yt. tune rev is pretty easy to under stand. you dont need to do all the bin prep stuff.
  18. #1198 Re: Some more top swap questions! Yay!
    Oct 2015
    So just to start off i need to work on learning the maf and timing tables the most just to get my kr to 0 and then i can fine tune and add timing as i go?
  19. #1199 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    the first thing you will need to do is get the dhp tuner, download the software, and get the software registered so you can read your bin. once you have your bin read, you can look at your good fuel timing table, and take a few degrees of timing out. then reload that bin and take a scan. I suggest using UV Scan, the newest one is the best, but whichever one you can get to work is fine. Eddies Table modifier thingy is a really good tool for making adjustments. I would start off reading the instructions on using the table modifier thingy, so when you go take a scan, you are scanning for all the parameters you need to make a good adjustment.
  20. #1200 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok thanks for tips i will deffinately be doing that!
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
