Thread: Some more top swap questions! Yay!
Page 53 of 71 FirstFirst ... 343515253545563 ... LastLast
Results 1,041 to 1,060 of 1411
  1. #1 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    So so far no more misfire codes..
    Sent from my LG-D851 using Tapatalk
  2. #2 Re: Some more top swap questions! Yay!
    are these old wires? or did you buy new?
  3. #3 Re: Some more top swap questions! Yay!
    Oct 2015
    There not new for this project but they are only a couple months old i just switched out that particular wire with one of my old ones. I have new coil packs to i still need to switch over cause the coil packs on it now are from a jy motor
  4. #4 Re: Some more top swap questions! Yay!
    Donating Users timboku's Avatar
    Montgomery, IL
    Are the trims? Any better?
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  5. #5 Re: Some more top swap questions! Yay!
    Oct 2015
    So i dont think i was able to complete the cycle when i was on break currently when im in drive at idle my st trim is pretty good inbetween +- 5 but my long term just sits in between +7 and +10
  6. #6 Re: Some more top swap questions! Yay!
    the ltft moving at idle still? or holding steady at one #?
    st @ idle should be 0.0 and dance to a low + or - # back and fourth.
  7. #7 Re: Some more top swap questions! Yay!
    Oct 2015
    St seems on point lt bounces from 7 to 10 at idle i went over the 40% throttle to check if it was ready and short term was 0 and lt was .8
  8. #8 Re: Some more top swap questions! Yay!
    Oct 2015
    Not wot just over 40%
  9. #9 Re: Some more top swap questions! Yay!
    if thats neg 7-10 so far thats not to bad, its rich at least,
    0.0 getting into the gas, its still not learned yet. unless the trims are spot on and thats a long shot.
  10. #10 Re: Some more top swap questions! Yay!
    Oct 2015
    No its positive 7-10
  11. #11 Re: Some more top swap questions! Yay!
    Quote Originally Posted by suitercrew View Post
    engine running spray the blower and tb gaskets and vac lines and the map and the bbv with carb cleaner, you just might have a vac leak.
  12. #12 Re: Some more top swap questions! Yay!
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    just want to be post #1050 on this long-ass thread.
    but i was too late...
  13. #13 Re: Some more top swap questions! Yay!
    Oct 2015
    Hmm wouldnt i hear a vac leak though?
  14. #14 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Not if it's really small if you spray the areas with carb cleaner the engine will rev up if there's a leak
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  15. #15 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    What does your upstream o2 read at wot?
  16. #16 Re: Some more top swap questions! Yay!
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    You should also notice your fuel trims change if your watching them while spraying
    2012 F150 STX
    - Gonna be a race truck
  17. #17 Re: Some more top swap questions! Yay!
    Oct 2015
    I dont want to go wot so i dont know what the o2 looks like. I have looked for vaccum leaks visually which is how i found my brake booster leak but fixing that didnt really help any
  18. #18 Re: Some more top swap questions! Yay!
    Oct 2015
    I will try the carb cleaner in the morning
  19. #19 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    I feel like your tune is off
  20. #20 Re: Some more top swap questions! Yay!
    Oct 2015
    I still have plans to get a tune on tuesday either way
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
