Quote Originally Posted by luckyg817 View Post
Did you check to see what the voltage for MAP is supposed to be vs what you got?
I checked the map sensor with a volt meter. I checked 5 volts coming to sensor from pcm when car was turned off. Then I checked voltage again with car running and it dropped down to 1.5 volts this indicates that the map sensor is good. I found a video on you tube that shows you how to check it.
Watch "Map Sensor Testing" on YouTube
Map Sensor Testing:*http://youtu.be/B8EVhFc5Yqw
