so i searched around here and could not find someone who had the exact problem i have. maybe because mine just started? the car stalled twice today in the taco bell drive thru. in drive the whole time, i finished ordering my lunch and before i took my foot off the brake i felt the engine shut off just as if i turned the key to accesory from ON, the radio and heat were still on with no problems. i restarted it like usual and pulled up and waited in line about 2 minutes when it did it again! i got my food, left, and whenever i came to a stop on the way back to school, i put it in neutral and gave it a little gas (just over 1000 RPMs) to keep the RPMs up and i didnt have any problems. my DIC is not currently hooked up (i should have my harness shipped to me next week) so idk if the TRAC light is comming on and i got no SES light. but the tach reads the RPM drop like it normally would during a normal shut off. the MAF was replaced last fall and plugs/wires replaced last summer.
any ideas? initally i thought something with the fuel pump or CPS or a coil pack going bad but after reading maybe its different? i drive alot so i want to make sure i get this at an early stage as i cant afford to get stuck anywhere.
thanks for the responses
