Thread: 04 GP Stalling Problem
Results 1 to 20 of 40
  1. #1 04 GP Stalling Problem
    Aug 2013
    arlington, tx
    Hey guys I was wondering if somebody could maybe give me an idea on what is going on here...
    http://s919.photobucket.com/user/luc...d6908.mp4.html
  2. #2 Re: 04 GP Stalling Problem
    is that your cel lit up? if so get it scanned for a code.
  3. #3 Re: 04 GP Stalling Problem
    Aug 2013
    arlington, tx
    No, it's not on. It's not throwing any codes. It started when I went to go wash my car saturday. I had the stereo on for about 2 hours while I was washing. It turned on fine as soon as I turned the key. You think maybe it could be my alternator going bad? I did see my headlights dimming when it started acting up. What's a good way to test an alternator? Cuz I turned the car on and disconnected the negative terminal and it kept running. That's how I was always told how to check it but they also said it was for the older cars. Idk.
  4. #4 Re: 04 GP Stalling Problem
    with a volt meter, or hit the parts store, they have a bat/alt tester.
    you want to see at least 12 volts off the battery car off. then test it again running, should be over 13 volts but not to much more then 14.
  5. #5 Re: 04 GP Stalling Problem
    Aug 2013
    arlington, tx
    I did check the battery. It's at 12v with the car off and 14v with the car on. I also checked for a dirty TB, it's got enough coolant, it's not overheating, no smell or smoke coming from under the hood. It's really weird.
  6. #6 Re: 04 GP Stalling Problem
    it kinda sounded like a miss fire of sorts. it had a tune up lately?
    what are your miles?
  7. #7 Re: 04 GP Stalling Problem
    Aug 2013
    arlington, tx
    I put new spark plugs and wires in a few months ago. It has 136k.
  8. #8 Re: 04 GP Stalling Problem
    Jun 2012
    south haven mi
    explain what its doing more if it starts right back up and keeps stalling its usually the MAF
  9. #9 Re: 04 GP Stalling Problem
    Aug 2013
    arlington, tx
    If it starts right back up and die immediately, it will either stall out when the rpm levels even out after the initial start up or it will stay on while I step on the gas but as soon as I let go to put it in drive, it stalls. In the video after it cut off, I let the car sit for about 10-15 seconds and it turned right on and was able to drive it 2 doors down back to my house with me just barely touching the gas.
  10. #10 Re: 04 GP Stalling Problem
    Feb 2014
    St. Louis
    Sounds like a MAF sensor, mine was doing the same thing. Hooked it up to a realtime data reader and my car was reading 0 for the air flow. Try pulling the sensor off the the air box, and see if you have any problems starting.
  11. #11 Re: 04 GP Stalling Problem
    Aug 2013
    arlington, tx
    I will try that. Will I have a rough idle or something like that with the MAF not connected?
  12. #12 Re: 04 GP Stalling Problem
    Feb 2014
    St. Louis
    Quote Originally Posted by luckyg817 View Post
    It shouldn't, I pulled mine out and it started up just fine and I drove it around just fine. Your car might run a little rich with out it, so i wouldn't drive for a long time with it out.
  13. #13 Re: 04 GP Stalling Problem
    Aug 2013
    arlington, tx
    Ok, I will definitely do that today. I don't have any problem starting the car and babying the throttle but as soon as I slightly put my foot into it in first gear and get it above 1500 rpm, thats when the problem starts. If I baby the throttle, it will shift gears and everything. It's very hard to explain man. Haha. As you can tell.
  14. #14 Re: 04 GP Stalling Problem
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    Did you wash the motor?
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  15. #15 Re: 04 GP Stalling Problem
    was this problem there before the tune up?
    if not what plugs did you use, and your sure the wires are on right?
  16. #16 Re: 04 GP Stalling Problem
    Aug 2013
    arlington, tx
    I did not wash the motor. I went with the oem plugs and wires and it had never had this issue before. It's the first time it's ever done this.
  17. #17 Re: 04 GP Stalling Problem
    Aug 2013
    arlington, tx
    If i'm not mistaken the top 3 cylinders from left to right are 2,4,6 and bottom 3 from left to right are 1,3,5 correct?
  18. #18 Re: 04 GP Stalling Problem
    as long as they weren't platinum plugs your ok
  19. #19 Re: 04 GP Stalling Problem
    Aug 2013
    arlington, tx
    Yup. That's how the wires are ran. I went with iridium too.
  20. #20 Re: 04 GP Stalling Problem
    Aug 2013
    arlington, tx
    Something that I also thought was kind of weird was that about 2 weeks ago, I was having a loud tapping/clicking noise coming from the engine. I had just finished up a head gasket swap so I thought it maybe was a loose rocker arm that was causing the noise. Took it to a shop, they said it was the lifters making the noise. Drove it home and the noise went away. Long story short, the noise went away on its own after a few days but on one of those days, it did throw a misfire in cylinder 1. The next day it was gone and that code has not returned either. Even with the noise and "misfire in cylinder 1", it did not affect performance at all. Throttle response was good, it shifted smoothly, temp was good and saw no sign of something wrong. It did sit about 3 months before the swap though. Could that code have been an early warning sign of something? Maybe a crank sensor?
  1. Stalling problem
    By 97gp97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2011, 09:28 AM
  2. differnt stalling problem
    By CTKGP09 in forum General Tech Discussion
    Last Post: 03-24-2011, 08:46 AM
  3. My stalling problem not fixed!
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-02-2010, 05:22 PM
  4. Stalling problem at Idle.
    By benner in forum General Tech Discussion
    Last Post: 03-05-2010, 09:58 AM
  5. Mystery Problem, Stalling And More !!
    By 02BlueGT in forum General Tech Discussion
    Last Post: 03-25-2008, 03:53 PM
