Thread: My stalling problem not fixed!
Results 1 to 6 of 6
  1. #1 My stalling problem not fixed!
    SE Level Member PTGsDaytona500GTP's Avatar
    Jul 2010
    Broadview Hts Ohio
    Ok so the other day I was driving home and stopped when my 00' gtp started to struggle and was around 500 rpm jumpin tryin to stay alive. So I cut it off and back on. It was fine until I began to drive home when it started doing it again but this time the engine light popped on. Then I went to autozone and they gave me the code p0101. So I frove home to clean my MAF sensor and then my car was working but still with a rough idle. My engine light even came off and I let it run for like 10 minutes. So next morining everything is fine until it began acting like it did the first time! I took my car home. Another thing is when my car is low in rpm and struggling it happens when my foot is off the gas, so if I press the pedal down my car comes back to life. Now with that being said, this problem began occuring at most 2 days after I took it to get the recall bc my car was smoking! Do think that they messed something up?? I was wondering if it was my MAP sensor? I keep reading about that. Somebody help me I need my car for college!
  2. #2 Re: My stalling problem not fixed!
    Bastard Reptile's Avatar
    Kansas City, MO
    Try checking all of your big vacuum hoses. It's possible that something's unplugged and causing it to chug. Could also be a PCV valve, it's not very expensive to replace, and it's easily a 5 minute job.
  3. #3 Re: My stalling problem not fixed!
    Good way to rule out the MAF sensor is to unplug it. If it runs fine then its the MAF.
    Also...do what the green guy said...check all the vacuum lines. Dry rot is a common issue with the rubber "T" fittings around the S/C, Fuel Rails, LIM, and MAP Sensor.
  4. #4 Re: My stalling problem not fixed!
    Kansas City, MO
    For it to stall out like that, it's usually a big vacuum leak. Even the Evap line that runs from the solenoid to the TB is a very common break.
  5. #5 Re: My stalling problem not fixed!
    I suggested the MAF because of the chugging and struggling to stay alive...a bad MAF will make it jump and chug too
  6. #6 Re: My stalling problem not fixed!
    Jul 2010
    Broadview Hts Ohio
    Ok I will let you guys know what happens thanx Green Guy and blue guy lmao
  1. Stalling problem
    By 97gp97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2011, 09:28 AM
  2. differnt stalling problem
    By CTKGP09 in forum General Tech Discussion
    Last Post: 03-24-2011, 08:46 AM
  3. **FIXED!** Fixing One Problem Created Another...
    By CSteen85 in forum General Tech Discussion
    Last Post: 04-09-2010, 08:31 PM
  4. Stalling problem at Idle.
    By benner in forum General Tech Discussion
    Last Post: 03-05-2010, 09:58 AM
  5. Mystery Problem, Stalling And More !!
    By 02BlueGT in forum General Tech Discussion
    Last Post: 03-25-2008, 03:53 PM
