Quote Originally Posted by luckyg817 View Post
How do you know the MAP sensor is still good? Have you tried changing out the PCV that goes underneath the MAP sensor housing?
I checked the map sensor with a volt meter. I checked 5 volts coming to sensor from pcm when car was turned off. Then I checked voltage again with car running and it dropped down to 1.5 volts this indicates that the map sensor is good. I found a video on you tube that shows you how to check it.
Watch "Map Sensor Testing" on YouTube
Map Sensor Testing: http://youtu.be/B8EVhFc5Yqw
