Thread: PCM problem??
Results 1 to 20 of 25
  1. #1 PCM problem??
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    I posted this before, but I was driving the dash flickered and the car died. The car would crank but not start. The fuel pump wouldn't turn on so I jumped to conclusion that is was the fuel pump because they go bad. (wish i didn't replace it, but i learned my lesson ) Also replaced the ignition switch. I tested the old fuel pump and it worked!, I then hot wired the new fuel pump while all connected in the car and it turned on. So while it was being hot wired i tried starting the car but that wasn't working. I opened the schrader valve and had 0psi. I checked the fuel pump fuse, relays. They were all good. But the only thing that mind boggles me is that when the key is in the on position the only light i get is the oil light and the security light. Isnt the check engine light usually on?? So that leads me in the direction that the computer isn't working or getting the signals from the fuel pump and not turning it on?? if anyone has ideas, please help im desperate lol. Im no car guy but i know the basics. Thanks guys
  2. #2 Re: PCM problem??
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    check power to the pcm there is a fuse check fuses it sounds like just you bcm is turning on
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: PCM problem??
    Where's the fuse to the computer.
  4. #4 Re: PCM problem??
    Sep 2012
    bridgeport,NY
    under hood box
  5. #5 Re: PCM problem??
    ohh, well i checked every fuse in that box so they are all good.
  6. #6 Re: PCM problem??
    Okay so I went into the pcm connectors. and tested some things. I tested the ignition power voltage and that was fine. I tested the pcm ground that was fine. and I tested the battery power voltage and had no voltage running through it.. so now what? Could that be the problem
  7. #7 Re: PCM problem??
    Sep 2012
    bridgeport,NY
    check the fusible link next to the battery
  8. #8 Re: PCM problem??
    I was looking all over for the fusible link. I couldnt find it anywhere.
  9. #9 Re: PCM problem??
    sections of the battery cable itself are fusible links.
  10. #10 Re: PCM problem??
    Sep 2012
    bridgeport,NY
    if your car is 97 to 03 im assuming, look at your underhood fuse box there will be a red cover on the top with a post and 2 or 3 wires fitted to the post. one of those will be orange(prolly faded a bit) it will also have some numbers on it. if you dont have power coming from that wire then the link is blown and needs to be replaced.
  11. #11 Re: PCM problem??
    I have a 2000 ftp. And on the fusebox there's a black wire going to the post. And a red wire for my sub woofers. No orange wire
  12. #12 Re: PCM problem??
    Sep 2012
    bridgeport,NY
    you get power to your subs?
  13. #13 Re: PCM problem??
    Yes. But I'm still confused about this fusible link you speak of
  14. #14 Re: PCM problem??
    TMK there's no link on the positive battery cables. And ...there should only be one cable to that post if you are stock.
  15. #15 Re: PCM problem??
    yes there is one cable.. so what do i do now bill? im on the right track just a little confused
  16. #16 Re: PCM problem??
    Make sure you have the right pin on the right connector for the right year. Then follow the schematic for which fuse power comes off and follow the wire if needed.
  17. #17 Re: PCM problem??
    Jan 1970
    Maquoketa, Iowa
    When my yellowtop battery died, something similar happened. I'd try a different battery if all else fails.
  18. #18 Re: PCM problem??
    thanks bill, where can i find a schematic for my 00 gtp. I looked all over google and I cant find anything, and Im 100% positive I tested the right plugs also.
  19. #19 Re: PCM problem??
    Sep 2012
    bridgeport,NY
    my car has 3 wires to that post and it came like that also for the pin out diagram i have a shopkey 5 account pm me info
  20. #20 Re: PCM problem??
    im still completely lost.. :/
  1. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  2. HUD Problem
    By WCF59 in forum Audio, Security & Visual Electronics
    Last Post: 09-23-2012, 01:37 AM
  3. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  4. LED problem!
    By 1BlwnGTP in forum General Tech Discussion
    Last Post: 09-26-2011, 09:58 PM
  5. How do i fix this problem?
    By thenervemann in forum General Tech Discussion
    Last Post: 11-01-2008, 01:49 PM
