Thread: upper 02 sensor?
Results 1 to 9 of 9
  1. #1 upper 02 sensor?
    Jul 2011
    idaho
    Does anyone have a good idea of how to get the upper o2 sensor off easily? I believe my cat is getting plugged up and someone said to take the upper o2 sensor out but I am having a hard time getting a wrench on it... any suggestions would be much appreciated... thanks
  2. #2 Re: upper 02 sensor?
    7/8" wrench
    O2 plug socket and ratchet from parts store.
  3. #3 Re: upper 02 sensor?
    I live here. TLSheff's Avatar
    I think the socket was about $15 when I bought mine 2 years ago... maybe a little more, but the few times used it has more than made up its cost. A wrench is a booger to get it off with considering how little angle room is behind the motor, do-able but busted knuckles will be in your future.
  4. #4 Re: upper 02 sensor?
    Sooookay TL, now show him the other O2 socket.
  5. #5 Re: upper 02 sensor?
    Dis wan???
  6. #6 Re: upper 02 sensor?
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    I used an o2 socket, then a 1/2 drive 1" socket, then a 1/2 drive swivel, then 3 extensions, to my 1/2 drive ratchet with a 5 foot long breaker bar.
    Even with the o2 hot from driving the car, and SOAKED in wd40, I still managed to break a craftsman 1/2" drive extension.
    PS don't use 3/8" drive, broke a swivel trying that.
    That's my story, good luck.
  7. #7 Re: upper 02 sensor?
    Shoulda used PB Blaster. It works well for those "rusted" in place parts.
  8. #8 Re: upper 02 sensor?
    Sep 2012
    Clarkston, MI
    Pssh wd40, pb blaster, same thing.
    OP, better yet, just cut the cat out. I did that so I don't have to worry about it getting clogged.
  9. #9 Re: upper 02 sensor?
    pb blaster is 1000x's better than wd40 but a socket on a 3-6 in. extension works great for o2's. May have to run the motor for a while to heat it up.
  1. O2 Sensor not working... P0171 new sensor still no data from O2?
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2012, 12:20 PM
  2. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  3. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
