Thread: LED problem!
Results 1 to 6 of 6
  1. #1 LED problem!
    queens
    I don't know if I should post it here or in general, but I need some help. I bought leds from the website where clubgp usually gets them from and I went to install them, when I did they all worked fine and all but when I go to turn the car on they stay on as well. now if I take the key off they do the normal wait a few secs then slowly shut off but as soon as I turn the ignition bam they turn back on. now I have had leds before but once I got these this happened. so then I bought another set from ebay and the same ****. whats going on? could it be a resistor of some sort?
  2. #2 Re: LED problem!
    is your switch turned on for the lights on the inside the dimmer thingy
    SMGPFC Member #10
  3. #3 Re: LED problem!
    queens
    nope switch is not turned on
  4. #4 Re: LED problem!
    Dec 2008
    Lawndale, CA
    What area did you put the LEDs in?
  5. #5 Re: LED problem!
    queens
    the floors, the rear, the side markers on the door, and the dome lights
  6. #6 Re: LED problem!
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    I havnt had a problem in my car like this for the issue you are describing. My reverse lights pulsate every now and then.
  1. Oil Problem
    By Enzo354 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2011, 07:41 AM
  2. Key Problem?
    By Shaun28382 in forum General Tech Discussion
    Last Post: 03-15-2011, 11:05 PM
  3. Abs/tcs problem
    By L KELLS in forum General Tech Discussion
    Last Post: 01-04-2010, 04:51 PM
  4. Hello and a problem
    By Syerix in forum General Tech Discussion
    Last Post: 04-09-2009, 12:57 PM
  5. First Problem Need Help
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 10-19-2008, 03:30 PM
