I posted this before, but I was driving the dash flickered and the car died. The car would crank but not start. The fuel pump wouldn't turn on so I jumped to conclusion that is was the fuel pump because they go bad. (wish i didn't replace it, but i learned my lesson ) Also replaced the ignition switch. I tested the old fuel pump and it worked!, I then hot wired the new fuel pump while all connected in the car and it turned on. So while it was being hot wired i tried starting the car but that wasn't working. I opened the schrader valve and had 0psi. I checked the fuel pump fuse, relays. They were all good. But the only thing that mind boggles me is that when the key is in the on position the only light i get is the oil light and the security light. Isnt the check engine light usually on?? So that leads me in the direction that the computer isn't working or getting the signals from the fuel pump and not turning it on?? if anyone has ideas, please help im desperate lol. Im no car guy but i know the basics. Thanks guys
