Thread: Problem with transmission NO REVERSE...Any suggestions of problem
Results 1 to 4 of 4
newmy1d Problem with transmission NO... 07-27-2012, 10:27 PM
brandonl2000 Re: Problem with transmission... 07-27-2012, 10:31 PM
newmy1d Re: Problem with transmission... 07-27-2012, 10:37 PM
Trannyman95 Re: Problem with transmission... 07-28-2012, 11:36 AM
  1. #1 Problem with transmission NO REVERSE...Any suggestions of problem
    Jul 2012
    toms river
    I have a 2000 pontiac grand prix, my car has run fine. All of a sudden I have NO REVERSE 1st or 2nd gear. Its like driving in third gear the whole time. Please help any suggestions or ideas what the problem is? Is the transmission shot? could it be a fixable problem? Thanx for any help or suggestions
  2. #2 Re: Problem with transmission NO REVERSE...Any suggestions of problem
    Grand Rapids, MI
    Well...common probs:
    No Reverse
    Wont move in any gear
    No Forward Cold
    Wont move in D or 3 only
    Perhaps one of these is you
  3. #3 Re: Problem with transmission NO REVERSE...Any suggestions of problem
    Jul 2012
    toms river
    Thanks for such a quick reply. So am I reading the No Reverse link correctly..... It could possibly be a fixable problem? Someone had said it could be low transmission fluid is that a possibility as well? Thanks again
  4. #4 Re: Problem with transmission NO REVERSE...Any suggestions of problem
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Since you are missing Reverse, 1st, and 2nd ranges I would suspect more of an internal problem than what is listed on our website for a reverse only problem. Your year range was one that could have a geartrain problem and will cause no reverse and feel very lazy and big lack of power moving forward. You could also have badly burnt or damaged input clutches which would result in an identical scenario. A partially blown channel plate gasket has been known to cause no reverse also, and if blown out enough could effect other ranges as well. Either way this isnt something you are going to fix in the vehicle.
  1. I need a few suggestions with my S/C problem ... plz
    By chuckbattams in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-10-2012, 10:35 PM
  2. New LED reverse lights problem
    By hockeybawler in forum Visual/Body Modifications
    Last Post: 02-07-2012, 12:55 AM
  3. transmission reverse problem
    By fremmy182 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-01-2011, 09:39 PM
  4. A/C Problem Any suggestions?
    By mycutlassblue in forum General Tech Discussion
    Last Post: 06-12-2011, 05:47 PM
  5. problem seeing in reverse at night with tints...
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 02-20-2009, 10:08 PM
