Thread: Front sub-assembly bushing and sway bar
Page 1 of 3 123 LastLast
Results 1 to 20 of 54
  1. #1 Front sub-assembly bushing and sway bar
    Donating Users Burgundyman's Avatar
    I want to replace front sub assembly bushings with a set from Dorman. But I am not sure if they are pressed in. I do plan on replacing front sway bar bushings too. I also ordered a new sway bar for the rear with end links.
    1998 Grand Prix - GTP
    RED- 4 Door Sedan
  2. #2 Re: Front sub-assembly bushing and sway bar
    Mar 2017
    Internet
    sub as in subframe? top sits in bottom one. they push together..not pressed though.
  3. #3 Re: Front sub-assembly bushing and sway bar
    Yes. Sorry subframe. Can I pop them out? Or do u need a puller?
    RED- 4 Door Sedan
  4. #4 Re: Front sub-assembly bushing and sway bar
    GTP Level Member buickman104's Avatar
    NYC
    They separate easily enough. Getting them back in required some grease to lubricate. Just be very safe about supporting the weight of the subframe and undo the dog bone mounts.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  5. #5 Re: Front sub-assembly bushing and sway bar
    I am a bit worried about being under vehicle with jack stands in place
    RED- 4 Door Sedan
  6. #6 Re: Front sub-assembly bushing and sway bar
    Shop wants $600 to replace front and rear bushings
    RED- 4 Door Sedan
  7. #7 Re: Front sub-assembly bushing and sway bar
    600 bucks????? never go back there again. get under your car, you need a 18 mm socket. 1/2 drive is best.
  8. #8 Re: Front sub-assembly bushing and sway bar
    Do you pry rubber from below?
    RED- 4 Door Sedan
  9. #9 Re: Front sub-assembly bushing and sway bar
    I did lower subframe when I replaced sway bar bushings a couple of years ago. I remember dropping subframe by removing bolts a bit
    RED- 4 Door Sedan
  10. #10 Re: Front sub-assembly bushing and sway bar
    jack stands under the car, then a jack under the sub frame middle, front or back same job. remove the front or rear bolts while the jack holds the frame up, then lower it enough to pop the old crap out.
  11. #11 Re: Front sub-assembly bushing and sway bar
    I'll be replacing the two for now closest to sway bar. I need to remove both bolts fully while supporting middle of subframe. Lowering jack should give me about 1/2 to 1 inch clearance??
    RED- 4 Door Sedan
  12. #12 Re: Front sub-assembly bushing and sway bar
    dont go lower then say 3 inches or you'll rip the steering shaft apart. and yes remove both bolts, lower the jack some.
  13. #13 Re: Front sub-assembly bushing and sway bar
    Loosen dog legs at the top of engine should allow subframe to lower easily? Last time I removed bolts and lowered jack it moved about 1/2- 1 inch. How do I get it to lower further?
    RED- 4 Door Sedan
  14. #14 Re: Front sub-assembly bushing and sway bar
    i find it hard to believe the jack was dropped and the frame stayed up there by its self and only dropped a 1.5 inches.
    heres at least 6 inches, rack is also removed. so no shaft in place any more to rip apart.
  15. #15 Re: Front sub-assembly bushing and sway bar
    Al right. Do I need to remove dog legs at the top?
    RED- 4 Door Sedan
  16. #16 Re: Front sub-assembly bushing and sway bar
    Would you suggest using a scissors jack or regular floor jack?
    RED- 4 Door Sedan
  17. #17 Re: Front sub-assembly bushing and sway bar
    ive used a bottle jack and a floor jack, both work fine. you can un bolt the dog bones if you like, cant hurt.
  18. #18 Re: Front sub-assembly bushing and sway bar
    Is it ok to add a slight bit of grease to move into place? I hope this solves my front clunk noise when pulling away or stopping. Definitely feel it in floor board.
    RED- 4 Door Sedan
  19. #19 Re: Front sub-assembly bushing and sway bar
    if need be lube em up.
    you might have a loose bolt if you had the frame dropped in the past. i had one that needed to be made tighter, did the clunk and could feel it in the floor under my feet. only from a dead stop.
  20. #20 Re: Front sub-assembly bushing and sway bar
    There are only two bolts in the back. I remember torquing them at 135 foot pounds. The mechanic several years ago added grease to bushing. Said it would help. Obviously it did not
    RED- 4 Door Sedan
  1. Front Sway Bar Bushing Bracket Bolt Trouble
    By Jackd90 in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2014, 09:13 PM
  2. Where to buy poly sway bar bushing?
    By slimguns in forum Brakes/Suspension/Chassis
    Last Post: 08-13-2013, 08:36 PM
  3. sway bar bushing help
    By kking89 in forum General Tech Discussion
    Last Post: 07-29-2013, 04:45 PM
  4. BMR Sway bar bushing PN or supplier?
    By Haney GTP in forum Brakes/Suspension/Chassis
    Last Post: 04-05-2013, 06:22 PM
  5. rear sway bushing?
    By speed demon in forum Brakes/Suspension/Chassis
    Last Post: 08-25-2012, 07:35 PM
