Thread: Front sub-assembly bushing and sway bar
Results 21 to 40 of 54
  1. #21 Re: Front sub-assembly bushing and sway bar
    Donating Users Burgundyman's Avatar
    1998 Grand Prix - GTP
    RED- 4 Door Sedan
  2. #22 Re: Front sub-assembly bushing and sway bar
    This is the kit I bought from AutoZone
    RED- 4 Door Sedan
  3. #23 Re: Front sub-assembly bushing and sway bar
    Mar 2017
    Internet
    FWIW here's pics from me doing the Bonneville ones
    Overall.. I had to pry them a bit, think I air chiseled a little as well for the super rusty crusty. Overall, took maybe 2 hours total, being super careful with two stands holding the car and two holding either front or back of subframe where I was working. Can't be too careful under there. Jack stands are cheap
  4. #24 Re: Front sub-assembly bushing and sway bar
    RED- 4 Door Sedan
  5. #25 Re: Front sub-assembly bushing and sway bar
    What is the order of assembly?
    RED- 4 Door Sedan
  6. #26 Re: Front sub-assembly bushing and sway bar
    I installed new trailing arms, sway bar and end links. But now the right side makes a creaky sound when climbing or descending a curb. Everything is super tight and torqued to spec.
    RED- 4 Door Sedan
  7. #27 Re: Front sub-assembly bushing and sway bar
    GTP Level Member
    Jun 2016
    Cleveland ohio
    spray down the sway bar bushing with lube to see if the noise goes away.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  8. #28 Re: Front sub-assembly bushing and sway bar
    Silicon spray? Remove bushing, spray and reassemble?
    RED- 4 Door Sedan
  9. #29 Re: Front sub-assembly bushing and sway bar
    GTP Level Member
    Jun 2016
    Cleveland ohio
    any lube like wd 40 or similar is fine. no need to take them off just spray well into the seam and around the bushing. Drive it around the block a couple times and see if the noise goes away or lessens. If the noise goes away or lessens then take the bushings off and grease them.
  10. #30 Re: Front sub-assembly bushing and sway bar
    Ah. Great idea. Thanks
    RED- 4 Door Sedan
  11. #31 Re: Front sub-assembly bushing and sway bar
    if it stops after spraying it, its gonna start again one day soon. so you can then take the cap off and the bushing, then wrap the bar with teflon tape, or grease it and put the bushing and cap back on.
  12. #32 Re: Front sub-assembly bushing and sway bar
    Applied teflon to rear sway bar. So far no more squeak.
    RED- 4 Door Sedan
  13. #33 Re: Front sub-assembly bushing and sway bar
    I had serviced transmission awhile back and torqued nuts according to specs. Noticed transmission fluid around base of pan. Do I need to re-tighten or replace gasket??
    RED- 4 Door Sedan
  14. #34 Re: Front sub-assembly bushing and sway bar
    did you not reuse the stock pan gasket? if you didnt, thats the problem.
  15. #35 Re: Front sub-assembly bushing and sway bar
    I installed a new one
    RED- 4 Door Sedan
  16. #36 Re: Front sub-assembly bushing and sway bar
    It was just like the other one. Neoprene with steel insert
    RED- 4 Door Sedan
  17. #37 Re: Front sub-assembly bushing and sway bar
    Did this back in March
    RED- 4 Door Sedan
  18. #38 Re: Front sub-assembly bushing and sway bar
    spray it all down with brake cleaner and keep an eye on it, could be a axle seal leaking and running down.
    or maybe its motor oil? my old engine leaked so bad the tranny pan got coated.
  19. #39 Re: Front sub-assembly bushing and sway bar
    Would it hurt to snug up?
    RED- 4 Door Sedan
  20. #40 Re: Front sub-assembly bushing and sway bar
    Can't see any transmission fluid leaking from axle seal.
    RED- 4 Door Sedan
  1. Front Sway Bar Bushing Bracket Bolt Trouble
    By Jackd90 in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2014, 09:13 PM
  2. Where to buy poly sway bar bushing?
    By slimguns in forum Brakes/Suspension/Chassis
    Last Post: 08-13-2013, 08:36 PM
  3. sway bar bushing help
    By kking89 in forum General Tech Discussion
    Last Post: 07-29-2013, 04:45 PM
  4. BMR Sway bar bushing PN or supplier?
    By Haney GTP in forum Brakes/Suspension/Chassis
    Last Post: 04-05-2013, 06:22 PM
  5. rear sway bushing?
    By speed demon in forum Brakes/Suspension/Chassis
    Last Post: 08-25-2012, 07:35 PM
