Thread: Where to buy poly sway bar bushing?
Results 1 to 11 of 11
  1. #1 Where to buy poly sway bar bushing?
    May 2012
    Albuquerque, NM
    Sorry for the noob question but I can't find them anywhere. I want to upgrade to the GMPP kit with poly bushing to match the rest of the mounts. Any help us appreciated.
    TIA,
    Slim
  2. #2 Re: Where to buy poly sway bar bushing?
    Nov 2011
    NY
    You've got to find out the diameter of the bar...
    then you can goto Energy Suspensions site and match the diameter of bushings to the bar, get part # and search the net and whoola!
    good luck!
    a little help...
    http://energysuspension.com/products...-Bushings.html
  3. #3 Re: Where to buy poly sway bar bushing?
    gardner,mass
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  4. #4 Re: Where to buy poly sway bar bushing?
    Arizona
    For that price you could just buy the correct poly sway bar bushings..
  5. #5 Re: Where to buy poly sway bar bushing?
    May 2012
    Albuquerque, NM
    Thank you guys! I guess I thought they were already in a kit. Appreciate the help.
  6. #6 Re: Where to buy poly sway bar bushing?
    I believe it's a 33mm bushing that you need.
    04 Comp G.
  7. #7 Re: Where to buy poly sway bar bushing?
    Try a 34 mm bar for an F body.
  8. #8 Re: Where to buy poly sway bar bushing?
    Dec 2008
    Lawndale, CA
    I got the part numbers from billboost37. You can find the part numbers in this thread that would work with the GMPP bars. I got mine through summit.
    http://www.grandprixforums.net/moog-...ml#post1080828
  9. #9 Re: Where to buy poly sway bar bushing?
    May 2012
    Albuquerque, NM
  10. #10 Re: Where to buy poly sway bar bushing?
    Ocala, FL
    Quote Originally Posted by slimguns View Post
    Yes, get the end links. They'll do as much as the bar itself.
  11. #11 Re: Where to buy poly sway bar bushing?
    May 2012
    Albuquerque, NM
    Sweet. Thanks. I'm thinking the bar/bushing/end links are really going to help out!
  1. sway bar bushing help
    By kking89 in forum General Tech Discussion
    Last Post: 07-29-2013, 04:45 PM
  2. Poly sway bar bushings
    By rhenuset in forum Brakes/Suspension/Chassis
    Last Post: 07-09-2013, 10:48 AM
  3. BMR Sway bar bushing PN or supplier?
    By Haney GTP in forum Brakes/Suspension/Chassis
    Last Post: 04-05-2013, 06:22 PM
  4. rear sway bushing?
    By speed demon in forum Brakes/Suspension/Chassis
    Last Post: 08-25-2012, 07:35 PM
