Thread: Headlight switch bulb
Results 1 to 2 of 2
  1. #1 Headlight switch bulb
    Feb 2017
    Wichita, KS
    Is it replaceable or do I have to buy a new switch? My switch works fine but the bulb is burnt out. 2000 GTP
    2000 GTP, CAI, ZZP front P-Log, ZZP 3" downpipe, 3.4" Thrasher SC pulley, Overkill PCM, 180 thermostat, BMR front & rear STB, 41-993 AC Delco Iridium plugs, ZZP rear sway bar (red, 18.3 mm), Moog rear poly sway bar bushings, Moog LCA's w/ problem solver front bushings, ZZP ceramic coated exhaust crossover, ZZP poly motor mounts
  2. #2 Re: Headlight switch bulb
    St. Louis
    Grab a used switch from a junkyard and call it done. Just be easy removing the dash trim as you may break multiple clips and then have even more rattles than the GP comes with stock.
  1. LED headlight bulb upgrade
    By pontiacgt500 in forum Audio, Security & Visual Electronics
    Last Post: 09-06-2016, 10:39 AM
  2. projector headlight bulb??????????????????
    By james ransom in forum General Tech Discussion
    Last Post: 02-24-2012, 10:35 PM
  3. Fog light switch indicator bulb
    By SnowDrift in forum General Tech Discussion
    Last Post: 11-16-2011, 10:20 AM
  4. Whitest headlight bulb?
    By Frank217 in forum Visual/Body Modifications
    Last Post: 05-18-2010, 12:58 AM
  5. headlight bulb
    By skidoojames151 in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 07:39 AM
