Thread: A/C System O rings
Results 1 to 4 of 4
  1. #1 A/C System O rings
    Jul 2015
    Kalamazoo, Michigan
    Hey, all! I bought a 1997 GTP in immaculate condition in the spring and the A/C wouldn't work. I bought a recharge kit and hooked it up, but when I give it pressure, the A/C system leaks right at the connection to the pump on the belt and the line that comes out. Has anybody done o rings on these cars before? Also, what size the o-rings do I need and do I need any special tools to pull the a/c lines?
    Thanks!
  2. #2 Re: A/C System O rings
    St. Louis
    Yea, you can get to the lines on the back of the compressor likely from underneath. Have to remove the splash shield I think. And since you will have to open the system up you should replace the accumulator/drier as well, which means more O-rings at that end of the lines as well. I know Oreilly's sells a kit with a bunch of different a/c O-rings in it and you just match them up. Should be green O-rings and a few orings with metal around them for the compressor side where you are leaking.
  3. #3 Re: A/C System O rings
    Jul 2015
    Kalamazoo, Michigan
    Sweet, so how do the lines disconnect? I haven't looked at it really hard yet, but do they just pull apart?
  4. #4 Re: A/C System O rings
    St. Louis
    They all have a nut that you have to undo. If they just pulled apart then they would never seal since the high side can run pressures of upwards of 250+.
  1. Piston/Rings
    By tomtom123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2014, 12:47 AM
  2. Hub Centric Rings
    By 505pike in forum Tires & Wheels
    Last Post: 02-27-2013, 01:52 PM
  3. Centering Rings on my new 18's
    By cboth686 in forum Tires & Wheels
    Last Post: 05-09-2009, 12:59 AM
