Thread: Front sub-assembly bushing and sway bar
Page 3 of 3 FirstFirst 123
Results 41 to 54 of 54
  1. #41 Re: Front sub-assembly bushing and sway bar
    wont hurt unless you snap a bolt off, if you clean it up you can see where its seeping from exactly. car off the fluid is way over the pans gasket.
    sometimes the pan bolt holes dimple, then the pans not pulled as tight. could try one of them metal plates some older tannys had to spread the bolts load out on the pan.
  2. #42 Re: Front sub-assembly bushing and sway bar
    Donating Users Burgundyman's Avatar
    Will take a closer look and see if any are loose.
    1998 Grand Prix - GTP
    RED- 4 Door Sedan
  3. #43 Re: Front sub-assembly bushing and sway bar
    RED- 4 Door Sedan
  4. #44 Re: Front sub-assembly bushing and sway bar
    The dorman brand does not look correct given the rear subframe bushing I just removed.
    RED- 4 Door Sedan
  5. #45 Re: Front sub-assembly bushing and sway bar
    It's a lot smaller and no flange
    RED- 4 Door Sedan
  6. #46 Re: Front sub-assembly bushing and sway bar
    RED- 4 Door Sedan
  7. #47 Re: Front sub-assembly bushing and sway bar
    This is the part number provided by AutoZone
    RED- 4 Door Sedan
  8. #48 Re: Front sub-assembly bushing and sway bar
    These are the GM parts number for the rear sub-frame bushings. I guess you can re-use retainer and bolt, which saves me about $30.00.
    10249731 Insulator, Upper....$38.93
    10248771 Insulator, Lower.....$18.75
    11611679 Insulator, Retainer...$10.80
    10410940 Insulator, Bolt.........$5.94
    RED- 4 Door Sedan
  9. #49 Re: Front sub-assembly bushing and sway bar
    New sway bar installed. Applied some teflon tape before installing bushing. Awaiting rear subframe bushings from GM
    RED- 4 Door Sedan
  10. #50 Re: Front sub-assembly bushing and sway bar
    Is this insert really needed when replacing upper bushing? I peeled it off from frame of body.
    RED- 4 Door Sedan
  11. #51 Re: Front sub-assembly bushing and sway bar
    Enfield, CT
    WTH? The subframe looks brand new
  12. #52 Re: Front sub-assembly bushing and sway bar
    Quote Originally Posted by HighOctaneRacing View Post
    I degreased it and wiped it down. I always try and keep it grease and oil free.
    RED- 4 Door Sedan
  13. #53 Re: Front sub-assembly bushing and sway bar
    Enfield, CT
    Well that's a good damn job lol
  14. #54 Re: Front sub-assembly bushing and sway bar
    Thank you sir. The rest of the car looks much like it...lol
    Regular upkeep is the only way to keep this car running optimally. Of course this means 💰
    RED- 4 Door Sedan
  1. Front Sway Bar Bushing Bracket Bolt Trouble
    By Jackd90 in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2014, 09:13 PM
  2. Where to buy poly sway bar bushing?
    By slimguns in forum Brakes/Suspension/Chassis
    Last Post: 08-13-2013, 08:36 PM
  3. sway bar bushing help
    By kking89 in forum General Tech Discussion
    Last Post: 07-29-2013, 04:45 PM
  4. BMR Sway bar bushing PN or supplier?
    By Haney GTP in forum Brakes/Suspension/Chassis
    Last Post: 04-05-2013, 06:22 PM
  5. rear sway bushing?
    By speed demon in forum Brakes/Suspension/Chassis
    Last Post: 08-25-2012, 07:35 PM
