Thread: Help w/ noise!
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #1 Re: Help w/ noise!
    Nope parked.. Expired tags in the trunk haha. Didn't want to reregister and throw insurance on it until it's driveable.. Which it is sort of but the noise has me rethinking.
    04 Comp G.
  2. #2 Re: Help w/ noise!
    Feb 2013
    37.295091, -121.930053
    Time for new gxp? And lower it?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Help w/ noise!
    No GXP for me and car is lowered already but I have plans for even more low
    04 Comp G.
  4. #4 Re: Help w/ noise!
    I'm a bit confused. What is so bad in that PB vid? Except..I don't see oil on the rockers..and I'd expect them to be slinging it all over.
  5. #5 Re: Help w/ noise!
    GT Level Member SilverBulletWI's Avatar
    Apr 2014
    Milwaukee, WI
    I had an issue with the top end of the engine not getting oil. Amongst other issues, turns out the oil pump gear and housing was all grooved up from grit passing through it. After that happens, it cannot build the pressure necessary to pick up the oil from the oil pan. I also think the oil regulator/spring was stuck. I have some picks in my thread if you link to my profile.
    Sent from my Tab3
  6. #6 Re: Help w/ noise!
    Were you able to view the YouTube video? The pb one you can't really here the tapping I'm referring to but the YouTube video you can.
    Quote Originally Posted by SilverBulletWI View Post
    Sent from my Tab3
    Hmm I'll have to check out your thread that could be a possibility
    04 Comp G.
  7. #7 Re: Help w/ noise!
    I'm at work.. no tube here
  8. #8 Re: Help w/ noise!
    Let me see if I can get it to upload on pb
    04 Comp G.
  9. #9 Re: Help w/ noise!
    Try that
    04 Comp G.
  10. #10 Re: Help w/ noise!
    That sure sounds like a single lifter to me
  11. #11 Re: Help w/ noise!
    Hmm they all seem to be fine and they pretty much brand new replaced them not to long ago. The question is what will BB do I'm sure there's a simple way to figure this out.
    04 Comp G.
  12. #12 Re: Help w/ noise!
    Well.. if you were BB, you'd have pulled out your mechanics stethescope and you'd know exactly where that noise is coming from. Since you aren't BB, you probably are on your way to the store.
  13. #13 Re: Help w/ noise!
    Already did that lol and still couldn't pin point it and nope no store for me
    04 Comp G.
  14. #14 Re: Help w/ noise!
    Did you listen on the exhaust pipes?
  15. #15 Re: Help w/ noise!
    Yea and still nothing. I held the stethoscope up to each cylinder where the header meets the head and the noise is constant throughout each one I then did the same thing but held it on the header instead and same results.
    04 Comp G.
  16. #16 Help w/ noise!
    Quick update before I get to drunk and forget. I worked on it a bit today and decided to throw some motor medic in the oil before I changed it. Let it idle for 7 mins. Changed the oil/filter noise remains.
    Now i was getting this noise before I changed the lifters and had a massive exhaust leak so I decided to fix both issues. New lifters were soaked in oil for a few days prior to me replacing. I checked the pushrods/ rockers before I threw them back in and they appeared to be fine and rockers were torqued down properly. With the vc removed I can't seem to pin point where exactly it's coming from. The valve springs seem to be ok. I haven't went as far as removing them just yet. No cel except for a abs issue and a P0650.
    Edit: dawned on me that I should measure and make sure I have the correct pushrod length since it seems some guys have problems using the stock pushrods with ls7 lifters... Duoh
    04 Comp G.
  1. Help!! WHAT IS THIS NOISE?!?!
    By illy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-07-2012, 10:56 AM
  2. Got a new noise. Might be transmission noise vid included.
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2012, 05:51 PM
  3. Tie rod noise
    By Bedwards in forum Brakes/Suspension/Chassis
    Last Post: 12-16-2011, 03:46 PM
  4. AC noise??
    By grandprix85 in forum General Tech Discussion
    Last Post: 07-20-2011, 08:07 AM
  5. Noise help
    By GMPUNK in forum General Tech Discussion
    Last Post: 02-08-2009, 05:07 AM
