Thread: Noise help
Results 1 to 2 of 2
  1. #1 Noise help
    Jan 2009
    connecticut
    When im on the highway and hit a dip that throws the car up, when it comes down I get a vibration sound, almost sounds like the tire is rubbing, but its definitly not that, i checked. It also does the same noise if I were to be going fast and hit a hill, same noise, it doesn't do it if i'm go slow over bumps or up hills. Any ideas?
  2. #2 Re: Noise help
    Feb 2008
    I would check out the whole front end out (ball joints, tire rods, struts, strut mounts, control arm bushings, sway bar end links and wheel bearings). I would also check out all the motor mounts and make sure that there is nothing loose around the belts. Hope this helps good luck and let us know what it was.
  1. ticking noise???????
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 10-02-2008, 12:27 PM
  2. Engine noise help please.
    By mathd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-01-2008, 08:50 AM
  3. HELP: tapping noise!
    By fst in forum General Tech Discussion
    Last Post: 08-28-2008, 10:46 PM
  4. .... Noise again
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2008, 04:15 AM
  5. What do you think this noise is?
    Last Post: 07-03-2008, 09:54 PM
