Thread: Help!! WHAT IS THIS NOISE?!?!
Results 1 to 9 of 9
  1. #1 Help!! WHAT IS THIS NOISE?!?!
    Apr 2012
    rhode island
    http://www.youtube.com/watch?v=vrIkIj4Rocg
    To me I think it might be a misfire but not really sure hopefully someone can chime in
    In my scan gauge It says 0 under knock ret but it's also jut idling idk if that makes a difference
  2. #2 Re: Help!! WHAT IS THIS NOISE?!?!
    Check engine like flashing?
    Any codes?
    Sounds like a miss.
  3. #3 Re: Help!! WHAT IS THIS NOISE?!?!
    I live here. TLSheff's Avatar
    Which noise? the thud thud thud thud thud like a cam (say that because we don't know what mods you have other than a intake and red valve covers) hint hint
    or the random whack sound that sounds like piston slap?
    Simple starter to help narrow this down.
    - Mods list please, miles on the car, any pertinent info you can think of.
    - Take both belts off the car, spin the pulleys by hand and make sure its not something simple like a bearing. (I really doubt this but its best to rule out the simple things first)
    - While belts are off, start the car, let it idle for a bit (keep in mind if you let it idle too long without a belt on it will get hot, no water pump spinning, don't overheat the motor!) see if it still makes the noise. This will remove any chance of the supercharger or accessories being the culprit and narrow it down to base motor problems.
    Come back and fill us in on what you find out.
  4. #4 Re: Help!! WHAT IS THIS NOISE?!?!
    St. Louis
    Kinda sounds like an exhaust leak to me.
  5. #5 Re: Help!! WHAT IS THIS NOISE?!?!
    Apr 2012
    rhode island
    Closin in on 200k
    just redid gaskets and other maintance on the car stripped most I the block down
    been sitting for about 6 months with the same gas. There is a sea foam in this gas now and there was some in the oil before I changed it
    In the vid the motor has just the serpentine belt on and very little coolant
    this is the first fire up since I've fixed everything. Oil pressure is good
    sound seems to be coming from inside the valve covers I'm not sure. The scan gauge says no misfires so idk what's goin on
    altho I think it could have to do with bad wires
    04 comp g btw
  6. #6 Re: Help!! WHAT IS THIS NOISE?!?!
    Apr 2012
    rhode island
    No lights no codes coming up. Going to double chek the order of the plugs also aand see what's up
  7. #7 Re: Help!! WHAT IS THIS NOISE?!?!
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    mine was making a smilar noise it sounded like valve tick but turns out my injectors were starting to fail
    Apr 2012
    rhode island
    I figured it out. The spark plugs were out of order and some was the headers hitting the fan. A little trimming of the plastic well e golden
    Apr 2012
    rhode island
    And it's still idling a little rough but it has a tank of old gas that needs to burn off once that's done and I put some new gas in I'll put my new 104s in and it should be running as smooth as a baby's bottom
  1. Got a new noise. Might be transmission noise vid included.
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2012, 05:51 PM
  2. Ac noise?
    By RyanL in forum General Tech Discussion
    Last Post: 07-27-2011, 07:12 PM
  3. GTP Noise....
    By SuperCharged0nE in forum General Tech Discussion
    Last Post: 04-02-2010, 12:01 PM
  4. odd noise at 27 mph
    By rossscrappy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2010, 06:01 PM
  5. .... Noise again
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2008, 04:15 AM
